MicroP25RX
W0RS
Nixa, MO
I am having issues with keeping the Micro powered up. I don’t believe it’s a issue with the MicroP25 but with the power cable I use, I have tried several. If I barely touch the cable the power shuts down. What power cable (manufacturer) is anyone having success with? 🤔🤔
KevinC
32D2T/957.282
I'm everywhere Focker!
I just used whatever random ones I had around the house and I’m having no issues…other than I did find one charge only cable.
maus92
OCMD
Before you buy a new USB-C cable, wiggle the connectors at the power supply and at the device while trying not to move the cable itself. That will rule out a connector issue. If you have tried several cables and have the same issue, it sounds like a port issue in either the device or the power supply. FWIW, a power supply designed for Raspberry Pi 4s will supply adequate power and is robust, for about $10 from Amazon.
dustinsterk
This is the incorrect cable for the microP25RX, the USB-C only works for the Wio screen to update the firmware (and the Wio screen comes with one in the box). To power the device you need a USB B micro like this -- https://www.amazon.com/AmazonBasics-Male-Micro-Cable-Black/dp/B07232M876
KevinC
32D2T/957.282
The MicroP25RX uses a micro USB.
FreqNout
Chicagoland
Is your 5v power source able to provide the current needed to power the MicroP25RX? Some USB power ports limit current.
btt
Jew lover
Wa State
I received your email. Looks for a response shortly.
W0RS
Nixa, MO
Well, it appears the Micro will need to go back for repair. After closer inspection, I must have at some point while taking the device out of the car pulled the power connection in an upward motion, thus pulling the device power connection up from the pc board. I may look at the case enclosure to see if I can provide a stress relief point so if I happen to do that again it will pull on the case enclosure and not the device power point ☹☹
Thanks for all the replies…👍
  • Like
Reactions: btt
KevinC
32D2T/957.282
That’s unfortunate, but I’m sure Todd will take care of it promptly.
maus92
OCMD
The current case design doesn't provide robust "strain" relief for the ports on the device. A USB cable plug and / or a directly attached antenna can exert lever moments to the physical ports on the device. I've seen some installations that use a sma antenna cable to mitigate the antenna port bending forces; maybe a right angle USB micro plug can shorten the lever arm for connection to power. I was thinking about mounting the device to a backing plate with standoffs, and devising supports for the antenna and cables because I know I would beat it up.
KevinC
32D2T/957.282
KevinC
32D2T/957.282
New FW...
2022-12-09
  • Improvements to sensitivity due to changes in P1 and P2 digital filters.
  • Fix lock-up issues when changing DEMOD / Gains for a newly added site.
goldmyne99
Todd released the MicroP25RX Wio Terminal code as open source on GitHub when the MicroP25RX first began shipping. It is available Here. If you have a little Arduino coding knowledge, you can make custom display screens for the MicroP25RX.
As an example, I created a second Monitor Mode display that has a TG History.
It updates/displays the last five active TGs on the Monitor Mode display.
Selecting Monitor Mode will toggle between the standard view and this TG History view. If you have ideas for a new Wio Monitor mode screen, it might be possible to create and add to the Wio FW.
Todd has updated the testing Wio FW to include this example screen.
2022-12-09 Wio FW Update.
Selecting Monitor Mode toggles between standard view and TG History view.
