MicroP25RX
robnj74
Buena, NJ
I like the talk group history, is there a way to change the color of the text?
  • Like
Reactions: btt
btt
Jew lover
Banned
Wa State
You can, but you will have to install the Arduino dev environment in order to modify the Wio display source. If you are interested and need help, then feel free to email. The github source is here: GitHub - tvelliott/MicroP25RX_Wio: Firmware source for the Wio-terminal portion of the MicroP25RX product
You would need to change this line (change TFT_BLUE to another color).
MicroP25RX_Wio/MicroP25RX_Wio.ino at main · tvelliott/MicroP25RX_Wio
This might be configurable in a future release.
btt
Jew lover
Banned
Wa State
A note to anyone having issues getting the Wio source code to compile. The latest versions of the Arduino development environment have issues. When you go to download, there is an option to load the previous 1.8.xxx versions. Use the 1.8.xx versions.
robnj74
Buena, NJ
After working with Todd last night and this evening I was able to get the font color changed. It wasn't actually all that difficult (literally a word change) save for configuring the software.
Todd thanks again for the help.
btt
Jew lover
Banned
Wa State
Excellent! Thank you for being patient and helping to find issues with the github documentation!
KMG54
Easley S.C.
All I can say is wow! I have multiple scanners, but in a simulcast area this is the cats meow. Keep up the good work and appreciate all your hard work. You did great here.
KMG54
Easley S.C.
Your work with the DSD files is spot on. Needs just a tad of tweaking, but you did well with the priority's. You need to join the Elon club with your talent.
btt
Jew lover
Banned
Wa State
Glad to hear it is still working well for you.
I know the RID import from DSD files is still missing. It is on the list. I'm not in the Elon club, but I am mostly an Elon fan. He does appear to be saving the free world single-handedly? I would like to see him completely restore free speech. I'm sure he is headed that direction. If he does, then I'm 100% in support.
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
Todd,
In the .ini file under (site) what does the Type do?.. What does "A" mean, "S" mean, "P" mean? What number is demod LSM?
Dave
dcr_inc
Delta, Pa
Is there a way to lock out a talkgroup from the WIO for more than 60 seconds? How?
KevinC
The big K
Super Moderator
1 point
In monitor mode, short press on the right top button when desired TG is active (to hold on it), then a long press on the same button and scroll down to disable TG.
This will do a permanent L/O that can only be reversed in the .ini file.
btt
Jew lover
Banned
Wa State
Todd,
Dave
A - adjacent / alternate site
S - secondary
P - primary
The skip function is fixed 60 seconds for now. As Kevin mentioned, you can disable a TG using the menus.
dcr_inc
Delta, Pa
Thank You all for the answers..
One more question.. What is a good antenna that can attach to the SMA connector on the Micro?.. I want something that screws directly on to the SMA without a cable.
btt
Jew lover
Banned
Wa State
I haven't found a good right angle antenna yet. Multiple people have reported that a REM800 antenna with an SMA adapter is a very good antenna. I'm thinking about acquiring one, but haven't yet.
robnj74
Buena, NJ
I don't know about perfect but I use a Motorola 800mhz antenna from my xts5000. It mates nicely to a 90 degree sma. It seems to do pretty well.
  • Like
Reactions: btt
