Correct Mark. I've seen the Maine tankers up there often. They usually use the callsign MOLSON 01 while up there.Couple McGuire KC-46's working up in Canada just North of CFB Bagotville.
Assume tanking local Hornets.
They were not using Molson today. I think Molson is a NORAD tanker callsign for Canforce missions so prob not needed today.Correct Mark. I've seen the Maine tankers up there often. They usually use the callsign MOLSON 01 while up there.
globe.adsbexchange.com
See post 2,768. This helo came through KRDG airspace and on adsb showed as BLKJK33 CH-46 Sea Knight. 07-08033.Earlier today saw a CH-47 and got some pictures.
View attachment 181912View attachment 181913View attachment 181914
Departing Andrews this morning MIGHTY-1 it sounds like on ZDC Blackstone 235.6251140 EDT MIGHTY1 or something similar on 261.200 Air Air
Working center ATC on 281.400 379.300 278.400 and VHF 132.275
MarkDeparting Andrews this morning MIGHTY-1 it sounds like on ZDC Blackstone 235.625
req FL-280 direct Montgomery.. New Bama F-35 perhaps?
I heard some on way in also the the other day.You were correct on Mighty.Mark
As I kept hearing it - it almost sounds like BAYOU - but it is tough to understand them sometimes
Terry
SAM629 01-0015 should be on the way to Paris with Sec'y of State, using dual hex codes. ADSBx has AE115D, ACARS has AE06F0, getting to be a common practice with many of the SAM flights. Also showing flight number as 582 in ACARS.
As if 2 tankers wasn’t enough, BISON 41 (KC-135R/63-8044) is now joining the party and working with SABRE and RAMBO flights1010 - MAINE 85 (KC-135R/58-0021) and MAINE 86 (KC-135R/58-0098) checking in with Boston Center (ZBW UCA09/ART08) will be working AR in Viper south with RAMBO and SABRE flights
Checked Ron’s list and both RAMBO and SABRE are Langley F-22 callsigns
1037 - SABRE flight advising they are going to gas then fight then gas up again followed by RAMBO flight gassing up, and then SLAM (Alert jets) flight will be getting gas last. (AR-609 Prim 276.500)
Making me think it’s Barnes F-15s
Yep SABRE 1 (x2) departed Barnes at 1021 EDT, and RAMBO 1 departed at 1049. The SLAM flight departed at 1039 and was a practice scramble to W105. A-A on 259.900 so far. SABRE and RAMBO seem to be fairly new MA callsigns, I've heard them use both before but only fairly recently.Making me think it’s Barnes F-15s
You got it. RAVEN was on 266.6 air to air. Working with JTAC DARKNIGHT ON 283.1.1010- NJ ANG x 4 finishing up at Warren Grove
1013- RAVEN x 2 entering Warren Grove airspace 266.6 283.1
1022- STEELE (58-0084) in W107 AR (with NJ ANG?) on 288.0
