Mid-Atlantic MilAir 2024
mdmonitor
0900- Lot of discussion between Banker 51 & Huntress (260.9) on moving CAP due to incoming wx. Probably moving CAP to Reading area to buy some time before wx hits. Noble 21 inbound to CAP. Coordinating hand off w/Noble 11. Noble 21 advises Noble 11 to use an eastern route, towards Langley, on RTB. Noble 21 flt came in that way. Worked ZDC Cape Charles (293.225) to ZDC Smyrna (354.15)
apex31
0944 local - Over King of Prussia, PA just heard loud fighter sounds from up high heading N/NE. Too much cloud cover to see anything, but it appears BANKER51 is tracking up this direction as well, must be NOBLE21?
Looks like they moved to the Wilmington CAP course due to wx.
Odd TFR that went up late last night for this afternoon in KILG area.. VIP visit of some type.
Expect OTR visit by Harris to campaign HQ as they've begun to switch from Biden for Prez to Harris in the past 24 hours. Let's see if I'm right with that.
Posted before I read @vgames15 response.
frank3si
New Castle DE
Looks like 09-0017 went in a big circle through PA and back to ADW. Maybe a maintenance run?
I was following that as well. At first I was wondering if it was the VP arriving at KILG early, but when it stayed in the 20K altitude range I realized that was not the case. Will be interesting to see if this is the same aircraft she does use this afternoon.
09-0017 is not a Vice Presidential aircraft, it is in the presidential stable.
frank3si
New Castle DE
I did not know that. I always assumed the C-32s were available to each of them as needed as a shared custody arrangement - didn't know specific aircraft were assigned to the president and vice president (other than the VC-25s).
09-0015, 0016, 0017, 0018, as well as the two VC-25s are all assigned for presidential use, they are not used by other government officials, nor the First Lady, absent POTUS being aboard, except under very limited exceptional circumstances.
@frank3si possible AF2 today 99-0004 which began process for flight, VP headed to ADW from White House at 2:41PM
CLEARED TO KILG ARPT MRNG1 EXPECT RV FIRST FIX THEN AS FILED MAINTAIN ALTITUDE (QNH): 3000 FT EXPECT 13000FT 10 MIN AFT DP, DPFRQ 125.65 SQUAWK 5634, ENGINE START PILOTS DISCRETION
