yes - exactly.....frequency usage is shared by many different operations.I've also seen 319.4 used as an AMC A2A.
The British tanker was working refueling with the fighters the other day on 263.100 which is also a Washington Center freq.
Yeah remember that too Ron. Martin State had some of the first C-130J's and as more came online the USAFMartin State's C-130s left years ago. Then they were replaced with C-27Js; then those left as well. Most of them went to the Coast Guard.
1538 local NOBLE-21 flight returning to A/C on ZDC 360.700 then ZDC (Casino) 285.400 and A/A 376.150.14:59 EST NOBLE 31 now departing unrestricted to 16K - departure freq is Washington Center on 285.400
15:03 EST NOBLE 32 is getting ready to depart - requesting unrestricted climb to 15K
15:06 EST NOBLE 32 departing unrestricted to 15K - departure on 285.400
If scramble.nl is correct, than they're both from different bases:10:42 local on 231.625 - NOBLE 21 gave tail as 87-289 (87-0289)
NOBLE 22 gave tail as 85-468 (85-1468)
				Both are with the makos now. Spads and WI stopped flying the 16s and transferred them to different squadronsIf scramble.nl is correct, than they're both from different bases:
#85-1468 F-16C 457th FS - Comment: '24 FS', AFRC an active associate unit of the 457th FS- KNFW Fort Worth NAS JRB (Carswell Field), TX
#87-0289 F-16C 176th FS - WI ANG - KMSN Truax Field ANGB @ Dane County Regional/Truax Fld Airport, WI
Someone filming aircraft scenes and arrivals via a drone?.. small radius at 3 miles.Checking NOTAMs around the area:
M0022/24 - UNMANNED ACFT WITHIN AREA DEFINED AS 3.0NM RADIUS OF NTU025007.2
(FT STORY/CAPE HENRY LIGHTHOUSE) EXTENDING OUT OVER WATER AND OVER
FT STORY. CONTACT UAS OPERATORS ON EASTERN COMMON FREQUENCY 239.45
PRIOR TO OVERFLIGHT OF FT STORY/CAPE HENRY. SFC - 700FT AGL, 15 JAN 12:00 2024
UNTIL 20 JAN 07:00 2024. CREATED: 10 JAN 19:24 2024
Anyone know what this is for?
