Missing Start Of Some Transmissions
infohou
Houston, TX
Hello Folks,
Now that I am hearing all sorts of things on the 106 I have a scanning issue. I am missing the beginning of some of the conversations. I know this was discussed but I cannot find it. There is apparently some setting for the amount of time the radio spends trying to determine the transmission type. Anybody know where that is?
Thanks,
Robert
RoninJoliet
ILL
If its a conventional freqy you need to set the "sq mode" the PL/DCS to search as the radio is looking for it...If its a EDACS trunk system the "EDAC TONE in the GLOB menu needs to be raised....
kel415
Kodak,TN
pro106 setting
I had the same issue with my 106 doing that. Don't remember who told me but was here on RR.Push pgm,func,global, scrow down to 5th line at DG Int prime and set it to 20. It seem to help alot but Istill will miss some at times. lol
infohou
Houston, TX
Not following that. Where is that for a conv?
Thanks,
Robert
infohou
Houston, TX
Trying that, thanks:)
SquierStrat
Fremont NE
Or if your scanning a trunked system and conventional frequencies at the same time, the trunked system being active would cause a delay on conventional frequencies... no fixing that tho; thats just how scanners work
