Monroe/Ontario County Project 25 Phase II ?
k2hz
Rochester, NY
I just had some activity on TG 1526. "127 to command", "we have 27 and 117 on scene", "17 to 27". It sounds like Fire Police.
mc48
Monroe County, NY
TG 1526 is looking to be North Greece Fire Secondary channel, they are using it mainly for Fire Police the same as Hamlin, Morton & Walker is using 1523. I have also heard them using it for training.
mc48
Monroe County, NY
I went ahead and submitted several Fire Battalion 2 Talk Groups, I had them programmed in and verified but never submitted.
I hope when they switch over on Nov. 2nd they turn off the VHF repeaters or links or whatever causes all the brief periods of dead carrier on some of the channels. Fixing whatever causes the temporary patches would be great also.
k2hz
Rochester, NY
The combination of temporary patches and switching between TDMA and FDMA is odd. Last night 1072 and 1075 were P2 TDMA but the other VHF links and the OPS TGs were FDMA. I doubt they will turn off the VHF links until RFD has fully transitioned.
w2csx
Rochester,NY
I had thought that RFD decided to stay on VHF and not transition to Harris system.
k2hz
Rochester, NY
I understand that RFD recently decided to join the system sometime next year. There are TGs assigned specifically for RFD use and some RFD units have reportedly been heard on the system.
billyfromhill
The new RFD talkgroups in the DB should be changed to Ops 2, Ops 3, and Ops 4 in line with the rest of the new fire talkgroups.
mc48
Monroe County, NY
The City approved money for RFD to implement and training for TRS in 2nd qtr. and Engine 3, 12 and Battalion 2 have been on the trunk on mutual aid calls with Gates Fire. They also will upgrading the station alerting system.
k2hz
Rochester, NY
If TG 1704, 1705, 1706 are Ops 2, 3, 4, what will the dispatch TG be? I have observed testing on TG 1702 and 1703.
billyfromhill
Ops 2 is supposed to be the new RFD dispatch talkgroup.
Bryx has been selected as the new station alerting vendor. I'm not sure if they're going to decode radio IDs over the new talkgroup or if it's some sort IP alerting solution through Byrx.
k2hz
Rochester, NY
I've yet to hear rfd dispatch reference any ops 2-4.
RFD obviously has not yet started to use the TRS for their own operations since it appears only a few units are equipped. RFD dispatch and non mutual aid operations are only on the TRS through the VHF patch TGs.
w2csx
Rochester,NY
The post failed to quote a previous post.
MonroeCny
11/2 is the switchover for County fire agencies to the ops talkgroups. No calls will be assigned to Fire 3 or 4. RFD to stay on Fire 1 and 2 for now.
k2hz
Rochester, NY
Channel 5 is remaining active, only 3 and 4 are no longer being assigned for response.
w2csx
Rochester,NY
Okay on 5. Thanks I am hearing engine 8 on the Harris system,wonder if that cause of the Henrietta district?
