..and you'll start to carry a 2135 key on your keychain and feel the power of the hero flow thru you.
Doesn't everyone?
We have found The One, and @BlueDevil is being indoctrinated as we type...Doesn't everyone?
I was thinking more like the Medallion from Raiders of the Lost Ark.Make sure you get the 2135 key glowing red hot so it leaves a nice brand on his right shoulder so we can properly identify him in the field.
............... I think you'll find a loose connection, or someone working in one of the telephone closets disconnected the circuit that had no dial tone on it (have had that happen before, tech needed a pair and just searched for the one with no dial tone on it and took it.)
Such things are worthy of a serious beatdown on the telco tech. I've also had telco techs testing leased lines in an analog voter system test by applying dialtone to the pair. Yes, honest to god, not lying. Sure makes dispatchers scratch their heads.
Like these.
Like these.
I had some free time this evening and I wanted to try out my 2135 key. I thought I would go take a look at the radio without the radio tech on site. So I made my way to the hospital and to the radio closet. Upon my arrival I found that the base station had been completely removed from the cabinet and was gone. I’m assuming the tech took it with him back to his companies radio shop in another city about 1hr away. This on top of everything else made my blood boil. On the up side, I did confirm my key works in the cabinet.
seriously. That's breaking appendages off in orifices type stuff.So it's completely acceptable to take a hospital radio completely offline with no spare or temp setup? Man, we would get hung if we did something even remotely close to that and would be named in lawsuits
The radio will transmit and pass transmit audio from the tone remote unit just fine.
The MTR2000 operates as a simple base station in simplex mode (TX/RX: 155.3400). In our system we don't use any DTMF codes to open the receiver or decoder. The base station operates with a TX/RX Tone of 146.2 Hz.
