Motorola XTS 3000 charger
Radioguy789
Ontario
Hello. I just got this new 4300 mAh XTS 3000 battery and the charger I have is model #: AA16740.
I put it in charge and for a little bit now both the Red (Charging) & Green (Complete) lights are blinking at the same time, I never seen my charger do this before. So just wondering what this means. Does it mean I don’t have the right charger for the battery or what.
i have attached a picture of my new battery & the charger I have
Let me know
VA4JOE
I have a different model of impress charger and under the red/green blinking lights it says "100% service life", whatever that means? Hope that may help you.
Radioguy789
Ontario
I don’t know what that means and I don’t have an impress charger. It’s an older one as shown in the picture and the model # of it. Mine just has a Red Triangle for charging and a green circle for charged.
VA4JOE
I'm guessing that a person would only see that the first time they charge a new battery indicating it has 100% of it's service life left?
Radioguy789
Ontario
Ok so my battery I just received like I showed in the picture, won’t work in the charger I have.
I will need another charger, a impress charger is what I will need to get
nokones
Sun City West, AZ
What is your battery chemistry? If it is a Lithium battery, you have the wrong charger. I believe your charger is for the NiCad and NiMH battery chemistries and not Lithium.
Radioguy789
Ontario
Ok and I posted a picture of the battery I just received. And it is a Lithium battery.
so I will need to get a Impress charger for it
n3obl
ØAES-1024
PA
yes. the older chargers dont support lithium ion.
nokones
Sun City West, AZ
You don't need an Impress Charger if you're not resetting an Impress battery each month. A non-Impress charger that will accommodate a Lithium battery charging cycle will do.
Although, you can also use an Impress Charger with a non-Impress Lithium battery.
If I were you, get an Impress Charger and battery if you want the battery to last 10 or more years.
Radioguy789
Ontario
I will repost the picture of the battery and charger I have
