mts2000 mic muted on repeaters
M0RFY
New to the forum, seems there are people here who know what they're about.
Here's a conundrum!
I have an MTS2000 model H01RDD9PW1BN: flash code 001008-000000-0
(I've attached a .CPG file renamed as .Doc...... so rename back to .CPG (it might work)) !
I have re-programmed mode A with the 8 446 Mhz PMR frequencies and a further 8 with a DLP code
Mode C I have programmed with the amateur 70 cms band U272 - U288.
I'm pleased say these are working fine.
Mode B however I intend to use on amateur repeaters, but have come up against a problem I can't resolve.
I have programmed the input and output frequencies as Rx 430.670Mhz & Tx 439.670Mhz cctss (PL) 82.5
I can hear other stations, the repeater can be accessed, but my voice is all but inaudible to other listening stations.
I can Tx to the input perfectly and I can Tx on the output perfectly. However through the repeater audio gets lost. My Yeasu 817 works the repeater just fine.
Has anyone come across this before?
  • 466IWE6641.doc
rescue161
KE4FHH
Hubert, NC
Most of the channels in Group B are assigned to conventional personality "1."
Other than that, you have the TX deviation set to narrow band (2.5 kHz). Most ham band stuff is not narrow band. Try changing that to 5 kHz and see if that helps.
rescue161
KE4FHH
Hubert, NC
Also, your TX and RX frequencies are not exactly "right" on pers 151. You have them as 438.6700 RX and 431.6750 TX. It is listed as "TEST" in your zone assignment, so I guess you're just testing. GB3-NS seems to be right, except for the narrow band thing. Change to 5 kHz and I'd bet that will fix you up.
A lot of ham repeaters are old/re-purposed equipment, most of which hasn't been properly tuned/aligned as well as being wide-band only. Let us know if that fixes the issue.
M0RFY
Thanks for getting back
band b personalities are set the same just to prevent out of band transmissions on previous programming and yes, per 151 is just a test setting.
I set the Tx deviation to 25Khz ......... No. still no audio.
I thought about reverse tones from the repeater muting the mic, but I think my programming negates that happening
M0RFY
Sorry previous post should read "I set Tx deviation to 5Khz" but ya al knew that anyway!
M0RFY
Hmm. Ok I'll have a twidle around the appropriate allignment, after I've saved the current set up!
Odd that both radios exhibit the same behaviour.
Also got to try them out on another repeater.
If I resolve it I'll post a report.
M0RFY
M0RFY
Well its been a while, but I have now resolved the issue.
Turns out the repeater was playing up. GB3NS had a few updates around that time and had a peculiar desensitising problem associated with its digital side.
Radios worked OK on other repeaters.
So all was well after all.
Many thanks to those who helped.
M0RFY
