all i can say is fantastic looking shack.
also might I suggest, running VNC on your computers? its a remote desktop software (free) that would allow you to eliminate all but one mouse and keyboard. That would help clear up some desk space.
I do remote desktop (XP Pro and Vista Ultimate both support it), and I have a KVM system also. But, I find I want to see at least 4 displays at the same time in max resolution, so that is why there are 4 monitors and 5 PCs. I tried doing it all on one monitor and mouse, went back to four. I even tried doing it all on one 42" so I could have multiple windows up at one time, still ended up going back to multiple monitors.
The old radios on the shelf. I have one like yours on the 3rd shelf up from the bottom. They look very similar.
It's shortwave and has tag from Bureau of Ships. If I send pics could you tall me more about it??
There are also 5 PCs installed under the desk to control radios and run logging and digital decode software. Each PC has a dedicated sound input, a radio that goes straight to it for record/decode, and also each radio goes to the mixer so that allows any radio or combination of radios to be sent to the amp/speakers, headphones, or separate record/decode PC.
There is other radio gear in the living room, but mostly just for display purposes. It all works but just gets turned on to show folks. For example:
Very beautiful. Id love to see the antenna's.
This is impressive. I do have one question that I hope, beg, and pray you can answer... You state that you have PCs for radio control and "decode", specifically "digital decode"... Could you elaborate on this further? I have about a hundred old scanners here, and I have searched every place I can think of to figure out if there's a way to "decode" the digital sound that comes out of my analog scanners... Logically it seems to me that I should be able to, but the reality is that I can't find any information on it... Is this what you mean by digital decode?
Another option instead of VNC is to use "Synergy". It will allow you to keep each of your screens in place, but set it up so that you use one mouse/keyboard. When you mouse off the edge of one screen, it pops to another screen. You'd set the "middle" monitor as the "server", then all of the client PCs would connect to it. When you go up, it'd go to the pc with the screen above the main one, right to right, left to left, etc... I use it here, and it works awesome! You can get it on Sourceforge. It's called Synergy2
You are the second person to suggest Synergy. I have used a KVM system form Avocent in the past, but liked having individual mice and keyboards. I will, however, give Synergy a try.
T!
Mohave Desert, California, USA
