Did another one of my mobiles a couple months back, the beater 1999 Chevrolet Blazer ZR2. Just got around to taking pictures of it though
Put in a Kenwood TS2000x with the RC2000 head, and the old Realistic PRO-2025 16 channel scanner that has served me so well for so long. I have a similar setup in my 1987 Bronco II also.
All HF bands, 160 to 10M, plus general coverage RX (I often monitor numbers stations and pirate radio while mobile), 6M, 2M, 70cm, and 1.2 GHz. The scanner gives me all local public service. Out here in the desert everyone is simple FM, no digital and no trunking.
In this pic you see 5 antennas, at the passenger rear corner is a 102" whip that with tuner I can load on almost any band. Drivers rear corner is a glass mount scanner antenna. On passenger side over door is a Diamond 770RHB dual bander, 2M/70cm, on the driver side over door is a monobander on 6M. Both of these antennas are on powered Diamond mounts, so they can be laid down for parking garages. The center mag mount antenna is a colinear on 1.2 GHz. The who thing, with everything laid down and the spare tire up top, comes in at under 7' 9", so I can get through most drive throughs and parking garages.
These two pics are of the overhead center console with the RC2000 remote head for the TS2000x.
This last picture is of the Realistic PRO-2025. It fit nearly perfectly when I removed the cassette deck that was in this location. Who listens to cassette anymore anyway? Above the scanner and towards the front of the console is the switch for raising and lowering the motorized mounts.
T!
