Hey guys I have a Radio Pro-164 and I need a new antenna for it. I am not listening to any 700mhz frequencies or higher. Theses are the radio frequencies I listen, to I live in El Dorado Hills, up the hill from Sacramento in California. I listen to the CHP 45.36000 Green Base and 42.72000 Green Mobile. I listen to all the El Dorado County Sheriff frequencies including 159.55500 160.69500 159.82500 159.69000 460.21250 155.79000 I also listen to Placerville PD 154.96500 154.75500 I also listen to all of the Cal Fire frequencies which includes Statewide Air Plan Freq. Cal Fire Statewide Command Freq. and Cal Fire Statewide tac freq. Amador El Dorado Union dispatch Amador Command and El Dorado Command. I also listen to all the USFS frequencies. I also listen to most of the California Emergency Services Radio System (CESRS) formally OES radio freq. I was thinking about buying this one right here. http://goo.gl/4y22FS It is the Hustler Antenna with coax cable. Is this a good antenna? I really tight on money so $30 is as high as I would like to go. The freq range that I will be listening to is like 40.00000mhz to like 500.00000mhz. By the way I have a 800mhz antenna right now and it sucks real bad. I can barely get dispatch and other freq and im only like 10 miles away or a little more. Yes I was stupid and did not read that it is made for 800mhz this is the one i have right now. 800MHz Scanner Antenna : Scanner Antennas | RadioShack.com
