Mongoosmike
Hopefully, you can change the file txt extension back to hpe and be able to view the favorites list of the upload file. The only compression program I have is rar and it didn't show on the allowable list to upload. I need some help with how to make several different favorites lists in Sentinel for my SDS-100, and then program each one into a quick-key position so I can listen to different areas as I drive around in the Bay Area. I have 3 different favorites list right now but they all show up in the same "tree" listing when I select each one using file~open on any particular favorite list. I also need some help with how to update the favorites list since I updated the database. I have changed a couple of things with the CHP listings and not sure if I update the favorites list it will update the new areas I opened up in the one of the lists. Oh I allso have not heard anything on the CHP Bronze frequencies, as I was listening the other night and when thy switched to that I lost listening contact. I didn't notice those in the favorites list, but it is a little confusing when trying to compare side by side with the database, opening different files. This is in California. Bronze - Base - Oakland (96) 42.120000 / Bronze - Extender – Alternate 769.681250 / Bronze – Extender – Primary 789-418750
Bronze – Mobile – Oakland (96) 42.400000
Thank you for your help.
