Need Motorola PM400 Code Plug
n7rnq
Oakdale, NY
Just purchased the new Motorola PM400 radio and need a code plug for amateur bands and fire departments. Anyone have a code plug they can share with me?
Thank you!
N2AL
Tennessee
A CP for fire departments and amateur bands? That varies literally from county to county across the United States. You would have to find someone close to the location in question, and see if they have a CP.
What other information can you provide?
n7rnq
Oakdale, NY
Sorry...I should of put in Suffolk County, NY UHF Amateur band repeaters only. I do not need the Fire Departments.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Thank you!
Do you have the proper software and cable for programming the PM400?
If so, why not add the channels yourself?
N2AL
Tennessee
If you have the ability to program the radio, here is a link to the Suffolk County, NY Amateur Radio repeaters. This was found on RR.com. You can program these into your radio.
http://www.radioreference.com/apps/db/?ctid=1876&tab=ham
n7rnq
Oakdale, NY
Yes, I have the correct cable and software. I have programmed some of the frequencies, but I'm not certain if I programmed the correctly. That is why I thought a code plug might help.
SteveC0625
You might also find some useful information at RepeaterBook.com
As for code plugs, why limit yourself to just the PM400? The CP200, CP200XLS, PR400, CM200, & CM300 all use same CPS. While you can't program your PM400 with a codeplug from any of the others, you can load them into the CPS and study them.
Frankly, trying to find a codeplug with frequencies you might want is not the best way to find frequency info. You are much better off with RR, repeaterbook, and websites for ham clubs in your area. They all will have accurate info. And a big bonus is that you will gain proficiency in programming by writing and then improving your own codeplugs.
