Lysander
I'm absolutely new to this; while I grasp theory, the practice seems to be eluding me. The manual for the PRO-163 reads as if there is an assumed base level of knowledge, which means I am grasping at straws.
I've tried to set up the scanner using the data on RadioReference for Fairfax County, Virginia's Motorola trunking system for emergency services (data: http://www.radioreference.com/apps/db/?sid=182 ) At least, most of the information is in the scanner. I started with block 0 channel 000 (to keep things simple); entered in the control frequency, 860.26250c (minus the "c") as the first frequency, then each other frequency, all set to "MOT" rather than "FM." When I hit "scan", it scans bank 0 (where the frequencies are) and occasionally spits out ID numbers. Other than the control tones, I get nothing else from the scanner's speaker.
From the Virginia subforum, it appears that there are voice transmissions "out there" - but I can't seem to get them. even when I hit "search" and pause on any one of the Fairfax County frequencies, I either get a control tone or nothing.
From the top, how easy is it to "fix" my attempt to set this up using the scanner. This is (supposed to be) a gift, so there's no immediate plans to buy additional software; if I can get this working now, then tat may be a possibility down the line.
Please help!
Please help!
