New Alinco DJ-X100 wideband receiver
RMW1010
Germany, EU
I contacted RT systems regarding software for the DJ-X100T. This was their response:
"We have the radio and have begun the development process, but we do not yet know if software will be a possibility at this time. Feel free to check back with us at a later date for an update regarding this software."
Jared
RT Systems
Tech Support
404-806-9561
Thanks for this info...
Hope they will manage, it's a very nice scanner, but Alinco's software is very basic, to say the least.
safemode73
Hi!
I have just purchased this scanner in version E. Unfortunately, the software from the Alinco website, not the one that appears here on the forum, does not work for me. When I use the writer from the manufacturer, it reads data from the device, but is unable to write anything, an error pops up.
Firmware version is 1.02, MCU 3.90-008
EditTool available at this forum is also unusable because the firmware version error...
Any idea?
Br.
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
Welcome to the RR forums. I don't own the receiver or the app but I'd recommend taking a screenshot of Ch 001 Column 1, perhaps it'll give us a clear picture of what might be going on...
Brunlea
A bit of a GEEK!
Lancashire
Hi!
Any idea?
Br.
I've the same radio and software version and I get the same error. I have to program manually at this time until a new firmware/software is available.
safemode73
Hello,
It's an empty cell, but it is not the case, even if this row is filled the error still here.
wokaokf
The frequency range (30-470MHz) of DJ-X100 is actually enough to cover commercial radios in Japan. P25 is used mainly by US forces in Japan and a few government agencies with encryptions. TETRA is mainly used at airports in Japan.
dsankir
Adana-TURKEY
Can someone tell me that T version can decode NXDN 4800 ? I ve got no luck even i had a full signal on single channel.İ m sure it s a n48 channel.
dsankir
Adana-TURKEY
Hello,
I ve update radio to 4.00 version for nxdn reception.Menu language back to Japan now.Any way to downgrade to 3.90 version for english menu?
dsankir
Adana-TURKEY
Hello,
Contacted Remtronix.Mr.Raj helped me a lot,finally i m back to 3.90 fw with English menu.But still no nxdn comms.
dsankir
Adana-TURKEY
W4KRR
Coconut Creek
Yes, this is the new firmware update. It comes with its own programming software. I don't know of any third party programming software available. Supposedly RT Systems may come out with their own.
Major changes:
Removed DCR mode from both E and T models.
NXDN(N) and (VN) modes are added.
Minor correction to AM sensitivity
FM radio step corrected to 100kHz (T-version only)
dsankir
Adana-TURKEY
I cant download for T version.There is empty files there.Can someone have it?
And so interesting now can decode NXDN48 now?
W4KRR
Coconut Creek
There's a "T" and an "E" version. I have the "T" version (USA). The "E" version is for Europe.
dsankir
Adana-TURKEY
Roger i have T version also.Updated new fw for T but no luck for nxdn.
I can listen same freq. with Uniden bcd325 and dn160 clearly but with Alinco still nothing.
imkesun
Thanks dsankir!
Main main PC still doesn't like the scanner (AMD CPU) , but parallels on my macbook did the trick.
Ran the upgrade, which went fine (see caveats below).
  • The hidden code (sqrt[2]) to enable POCSAG is now gone in the E-Model
  • All DMR channels where changed to NXDN(N) mode
  • All dPMR channels to NFM
  • ACARS,NFM,AM,D-STAR remained as is/was
  • CTCSS was also untouched
CSV Export does not include the bank information...
I definitely need better programming software for this unit !
