New Alinco DJ-X100 wideband receiver
jasej
Hidalgo Texas
Hi @jasej
How is this possible?
Mine doesn't show TG, ID. It only shows RAN and has problems decoding NXDN96.
My model is DJ-X100E
Can you tell us how you have configured it to give you that information and the encryption key information?
Thanks a lot.
My friend
That comment I wrote earlier comes from a comment from someone in the group who confirms that the Alinco DJ-X100E works and shows encryption numbers for 4800 Mbps, 16-bit, It includes RAN numbers, and of course you can hear those conversations.
vselic
I have few questions, some I found answers, but maybe if anyone else tried:
- how does it work on CAP+ channels? Does it do trunking? What about if it's cap+ channel but you monitor only one frequency, does it decode proper or messes it up due to too much data on cap+ bursts?
- how does it work on RAS MotoTRBO? does it ignore it, like other scanners/sdrs?
- does it decode dmr messages if it does?
- does it decode POCSAG messages?
- how fast does it scan through dmr channels or maybe mixture of everything? If i put idk 30-40 channels, how fast would it scan through, does it stop on data bursts or it proceeds, if there is no voice call?
Carballo
The scan is very fast, and you can listen to RAS, but it only gives you the slot information. Nothing else.
CAP+ isn't initially ready, but neither is my Uniden 3600XLT, and knowing the frequencies, you can store them in a bank and listen.
I hope this has been helpful.
vselic
Thank you. I think this scanner has a potential, you have answered me exactly what I need to know. I will order it for a testing purpuses.
RMW1010
Germany, EU
I have the DJ-X100T (US version). I've had it for 1 month so far and really enjoy it. I've done a bunch of programming from the keyboard while waiting for Alinco to post fully functional software for this version. Remtronics has a very basic version posted in the meantime, but it will not work with my radio, perhaps because I am not willing to risk all that I have programmed into it manually. No ETA from Alinco. Also, RT Systems says they are developing software for it too. No ETA either.
Any news on the RT Systems software? Hoping it will also do the E version
W4KRR
Coconut Creek
I contacted RT systems regarding software for the DJ-X100T. This was their response:
"We have the radio and have begun the development process, but we do not yet know if software will be a possibility at this time. Feel free to check back with us at a later date for an update regarding this software."
Jared
RT Systems
Tech Support
404-806-9561
RMW1010
Germany, EU
Jared
RT Systems
Tech Support
404-806-9561
Thanks for this info...
Hope they will manage, it's a very nice scanner, but Alinco's software is very basic, to say the least.
safemode73
Hi!
I have just purchased this scanner in version E. Unfortunately, the software from the Alinco website, not the one that appears here on the forum, does not work for me. When I use the writer from the manufacturer, it reads data from the device, but is unable to write anything, an error pops up.
Firmware version is 1.02, MCU 3.90-008
EditTool available at this forum is also unusable because the firmware version error...
Any idea?
Br.
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
Welcome to the RR forums. I don't own the receiver or the app but I'd recommend taking a screenshot of Ch 001 Column 1, perhaps it'll give us a clear picture of what might be going on...
Brunlea
A bit of a GEEK!
Lancashire, UK
Hi!
Any idea?
Br.
I've the same radio and software version and I get the same error. I have to program manually at this time until a new firmware/software is available.
safemode73
Hello,
It's an empty cell, but it is not the case, even if this row is filled the error still here.
wokaokf
The frequency range (30-470MHz) of DJ-X100 is actually enough to cover commercial radios in Japan. P25 is used mainly by US forces in Japan and a few government agencies with encryptions. TETRA is mainly used at airports in Japan.
dsankir
Adana-TURKEY
Can someone tell me that T version can decode NXDN 4800 ? I ve got no luck even i had a full signal on single channel.İ m sure it s a n48 channel.
dsankir
Adana-TURKEY
Hello,
I ve update radio to 4.00 version for nxdn reception.Menu language back to Japan now.Any way to downgrade to 3.90 version for english menu?
dsankir
Adana-TURKEY
Hello,
Contacted Remtronix.Mr.Raj helped me a lot,finally i m back to 3.90 fw with English menu.But still no nxdn comms.
