Hi. The issue with the original version is because you're using a Mac. Try the version I posted on Aug 29 in a msg to fafax. He said that version worked on his Mac.
I used the version of Aug 29. I can write the two .xlsx-files on my Mac with Excel and your spreadsheet. But I can't read the two generated .xlsx-files on my Mac with Excel. OpenOffice on my Mac shows error 2015 at the first line in the .xlsx-files.Hi. The issue with the original version is because you're using a Mac. Try the version I posted on Aug 29 in a msg to fafax. He said that version worked on his Mac.
Looks like it is caused by the way of error handling:I used the version of Aug 29. I can write the two .xlsx-files on my Mac with Excel and your spreadsheet. But I can't read the two generated .xlsx-files on my Mac with Excel. OpenOffice on my Mac shows error 2015 at the first line in the .xlsx-files.
Oops, that was a typo in my post, but it was correct in the cell. as you can see.The close quote is in the wrong place. It should be before the ).
Yesss!!!OK, try this version. I replaced the TEXT function with string functions that should not be affected by regional settings.
That looks correct. Glad it worked. I don't think there is anything else in there that is language or region specific/dependent, but if you find another issue please let me know. Now that I have Excel working in Mac, I can test under Windows and Mac before the next version.My macOS is in English, Excel is in English, but my region is Netherlands.
Great that you found how to make it independent of the region. Now it will work in other countries too.
