New Firmware release information
AM909
Radio/computer geek
SoCal
Is there an announcement email list? I'm on the EFJ list and get the Sharefile update notices, but I have to check the Kenwood pages and my brain has to parse the page correctly, which is not guaranteed. :| Even then, you get things like where in a recent update, they left the header date on an item the same and just added "Updated xx-xx-xx" in italics in the middle of the details.
If there's not an update notification list, has anyone used a good tool that you can give a list of pages and have it tell you when one changes (in a meaningful way)? I have some stuff I wrote a long time ago for specific purposes, but it might be tough to resurrect.
NXR-1x00 repeaters.
FW 2.30 is the latest I've seen.
Was told 2.21 addressed a network connectivity issue where the NXR does not recover after network connection error. This was related to an issue I had with a few NXR-1800's with early firmware that have the Multi-site conventional IP network option.
wsp44
With the NX-5300, can anyone confirm that ARC4 and AES256 are working fine now on Phase 2 Systems?
I know of folks using ARC4 on P25 conventional without any issues, I can't speak to ARC4 or AES256 on P25 P2 systems, but I would think as long as you had the correct Key ID and correct key data it should work, AES would also require the Hardware encryption module.
As far as I know there isn't a list, I just see it under the "what's new" on mytools when I login
AM909
Radio/computer geek
SoCal
... As far as I know there isn't a list, I just see it under the "what's new" on mytools when I login
That helps! I never see that page because I leave several tabs open and stay logged in. Thanks. :)
BTW, this anchored link scrolls down past the giant banner, at least for now.
Giddyuptd
Here and there
Would be nice if they would adjust the look back timers in a firmware update on the nx line to go lower or similar to that of the tk2180 in priority mode.
wsp44
11/12/24 Viking subscriber FW update 8.42.30 and Armada 1.42.23
Release notes below
kd4efm
EL98 Florida
Effective Dec 1, 2024 I will no longer be providing support within this forum.
Thank you for your support and look forward to see you all in other forums.
Any DM's requesting support will be deleted, I would ask you contact your local dealer for assistance or the helpfulness of the other members here who are just as good in their field of knowledge.
