New Jersey Interoperability Communication System (NJICS)
Highpockets
Toms River, New Jersey
Steve I guess one day I'm going have to call you and add some of these to the existing file you created for me I also read on here there are some federal and TSA frequencies I probably can pick up from Newark and Newark International Airport as well...Sooner or later I'm going have to figure out how to input these because apparently more and more stuff is added.
You have time, right now I find nothing interesting to listen to on that system, but I'm sure down the line I will enable that scan list and start to listen more often. :D
elias1988
West Creek,NJ
3085 - Maintenance - Central Crew 33 Area
Emergency Alert System tests on 3607 and 3613...I heard EAS tones on 3613 last week also.
rr60
New 700 Site now OTA
The below site was turned up last week. 774.78125 Site ID 039Ah-0101
Getting DOT Simulcast Id's 3631 & 3625 and such.
Thanks for the "input" and thread name change.
The hardware is in and antennas were just put up this week for a big footprint
system (sorry no pictures) but I did see the stuff.
I will not say the exact location but only that it is above 600 MSL and will cover
Union Somerset Middlesex and some Essex, Hudson, Monmouth, Morris, Mercer.
Control channel is not up yet, but I am keeping an eye/ear for it :)
N2ICV
Gloucester County FM29in
NJ PSIC Wiki ?
In the wiki TGID's 2237 and 2289 have "Patched 5-Comm ops from the 800 system" What 5-Comm? There is 3 5-comm's Troop A, B, or C?
elias1988
West Creek,NJ
EAS tones have been confirmed on 3607 and 3613 with a radio ID of 61361
3349 is currently patched with Troop C Criminal Investigation Bureau 4 ops from the 800 system
elias1988
West Creek,NJ
I am seeing new ESP radio IDs pop up and being used the past few days,by looking at my identified list it looks like they're replacing the old IDs.
ESP South is still being simulcasted from the 800 system....
CqDx
US
Are the new ESP radio IDs in the 91XX range and 96XX range? I see them affilating to the system, but none of them are the 4XXXX DOT IDs I used to seeing.
ScanXO
formally East Jersey part time south of the Border
This may have been posted but does this new system have anything to do with the 800 talk groups hanging up after transmissions, then the transmissions resume on another TG ?! mixed with that TG tx? otherwise I have constant 800 tg's hanging up and not hearing a response after a tx
elias1988
West Creek,NJ
The IDs are in the 44xxx and 45xxx range,I have seen IDs in the 91xx and 96xx range however they are only forced affiliations so far.
elias1988
West Creek,NJ
3093 appears to be another Central Maintenance Crew channel,I'm not sure which one at this time...
GTR8000
NY/NJ Database Guy
BEE00
I'm picking up CC's on 770.70625 and 770.71875 in the Tri-States area.
I believe we already determined that 770.71875 is Site 027 or 127 at Hill 1606 in Walpack, Sussex County.
Based on the higher RSSI I'm getting on 770.70625, I believe this may be High Point that has just recently come online.
I initially thought I was picking up the same signal on both frequencies, however when I listened to them simultaneously with two different scanners, the signals do not match up. Using frequencies just 12.5 kHz apart within the same county from two very good sites seems like it's cutting it pretty close, but I suppose it's possible.
Once again I note that I'm hearing this stuff with analog scanners, I have no way to actually decode the CC data. If someone in the Sussex County area can check my findings, that would be great.
