emcomm
It's actually an ingenious plan, so they don't have the replace the entire radio infrastructure, yet can migrate to encryption. To hell with the FCC and it's narrowing......
UF-49 said:When our Department radio network eventually becomes encrypted over the next several years, all current programmed radios will be obsolete.
Danny37
They also had coverage in Yonkers for many years due to it's hilly topography but they were able to finally overcome it years ago. Seems like every major PD that upgrades is going encrypted.
They should do a scanner buy back program with the guns!! LOL
Danny37
Says "The smaller VX-824 will no longer be distributed to precinct personnel." I wonder if the 824 will remain along with the 949 in the same way the VX-800 was used along with the VX-537, ie. distributed to bosses and specialized units.
I doubt it if they're going encrypted, even though the P824 radio is encryption capable. It looks like all UMOS despite rank or squad will be issued the 949 radio. Also no pool radios, so bye bye EMS, DHS and any other agency on the system .
One piece of important info that most of you will not be aware of is that not too long ago, the NYPD had Motorola design a new comparator (voter) specifically for them. It is the GRV 8000, and is capable of voting both analog and P25 conventional within the same piece of hardware. Its purpose is to not only support a mixed-mode channel with the top of the line G Series equipment, but to also make the transition from analog to digital seamless.
GRV 8000 Comparator - Motorola Solutions
The writing is on the wall, fellas.
GRV 8000 Comparator
Best in Class Project 25 (P25) Audio
HA HA.. best in class. Think they hired a car marketing firm for that one.
APX8000 has the longest in class antenna.
They need a DMR multisite solution!
Yes multisite instead of BDA's.Quite honestly; if they are going to have problems with a P25 signal being very badly faded in the tunnel with multi-path issues causing decode problems (as evidenced by the really bad crappy analog audio), DMR will fair no better. Both P25 and DMR would have the same cliff issue when the signal becomes too degraded to properly recover.
Unless you mean by multi-site they should do away with the BDAs and install equipment directly in the tunnels.
