The Official CR-1 Specifications Sheet released today
Introducing the New CR-1 Communications Receiver
The CR-1 is a small, low-power, ruggedly constructed radio-receiver that is finding a niche in the world of SWL’s (short wave listeners) and amateur radio enthusiasts.
The CR-1 is a new Software Defined Radio (SDR) from the designers of miniature wideband signal intelligence receivers developed for special-operations units and rugged business-jet data-link transceivers.
The CR-1 SDR is independent of a host PC, using embedded digital signal processing technology providing a degree of portability and performance previously unavailable to the radio enthusiast.
As one potential customer noted: “It’s an SDR with knobs, keys, and a display!”
Frequency Coverage and Modes:
MW-HF: General Coverage: 500 kHz - 30.000 MHz
• User Configurable Band Key:
o Amateur Band Selections: 160 m – 10 m
o International Broadcast Bands 120 m – 11m
• AM-SSB-CW auto-mode-selection (based on tuned frequency) with user-override.
• International Broadcasting: auto-select AM - 5 kHz steps - cursor override
• Auto-Filter Width select with override: AM: 6 and 7.5 kHz kHz/SSB: 2.6 kHz/CW: 1 kHz
• Tuning Resolution (cursor control): 1 MHz / 100 -10 - 1 kHz / 100 - 10 Hz
VHF-UHF General Frequency Coverage:
• VHF: Continuous Coverage: 64.0 - 225.0 MHz
• UHF: Continuous Coverage: 437.0 – 468.0 MHz
• Automatic standard frequency steps for each band
• Cursor Controlled (override) Tuning Resolution : 1 MHz / 100 - 10 - 1 kHz
VHF-UHF Band Plan:
• Aircraft Band: 108.000 - 136.975 MHz, AM auto-select -25 kHz channel steps
• Amateur: 2 m, 1.5 m, 19 cm (upper portion starting @ 437.0 MHz); with user selectable standard frequency steps. NBFM mode default with SSB-CW mode selects.
o Note 6 m (54 MHz) is not available.
• Marine & NOAA Weather Radio
• Public Service: 137.0 - 225.0: 12.5 and 25 kHz steps. NBFM default.
• FRS-GMRS 462 – 467 MHz , NBFM - 25 kHz Steps
Receiver Architecture
• HF: Dual conversion (VHF-UHF: single conversion) with low-IF , I-Q digital sampling, 16 bit DSP with digital audio CODEC
• DSP demodulation algorithms: DSB-AM, SSB, CW, WBFM, NBFM
• DSP scalable, fixed bandwidth channel filtering
Audio System – (Digital CODEC)
• Speaker Driver: 0.8 W into 8 Ohm load
• Internal 2.5” diameter, Mylar communications grade speaker
• External monaural speaker jack (3.5 mm stereo jack - back panel)
• Headset Driver: 40 mW into 16 Ohms. (3.5 mm stereo jack - front panel)
Antenna Inputs
• MW-HF Port: 1000 Ohm – 3.5 mm audio jack (auto-detetion)
• MW-HF Port: 50 Ohm – BNC (female)
• VHF-UHF Port: 50 Ohm – BNC (female)
Display
• 64 x 128 OLED Display with EMI filtered-lens
• Readable outdoors and manually dimmable
Power Inputs
• USB and 6-18 VDC – 2.1 mm diameter center pin (positive) jack
Power Consumption
• < 1.0 Watt
USB
• Mini-B –USB 2.0 Jack (powered): Downloadable software updates from CommRadio Website
Mechanical
• Overall Size: 5.64” W x 2.43” H x 6.10” D (including knobs, jacks , feet)
• Weight: 1 lb – 12 oz
• Knobs: Machined Aluminum – Black Anodized
• Front Panel: Machined Aluminum – Powder Coated – Black semi-gloss
• Case: 20 Gauge Steel, Powder Coated – Black Crackle.
ESD Protection: ESD Diodes: Antenna ports - Power Jacks - USB Port-Keys – Knobs
Hardware Design Limitations:
• The CR-1 is not controllable over USB by CommRadio or third-party software at this time.
• I-Q analog and/or digital IF signals are not ported to the rear-panel or accessible or at a standard sound-card sampling rate.
Software Demodulators Not embedded in the CR-1 at this time:
• Mono or Stereo FM broadcast Demodulator
• P25 or Trunk Radio
• D-STAR
• DRM
Always Free: Planned Software Upgrades:
• SW revisions and upgrades (improvements)
• FM broadcast demodulator (US and International)
• European Band Plans: MW- 9 KHz Frequency Steps
Potential New Software Applications (provided free if they occur, but not guaranteed to all new customers in 2013):
• Spectral Display (across individual bands) – fast detect of band openings
• CW reader ported to display and over USB
• PSK-31 decoder ported to display and over USB.
• Tell us what you want.
Origin & Warranty
• Designed and manufactured in USA
• Limited 1 year warranty on parts – labor – workmanship
