TwoToneDetect New TwoToneDetect in the works - Python based
DC31
Massachusetts
start with page 19 in the TTD manual (attached). Ask if you need help, the setup of the web server can be challenging.
  • TwoToneDetect_Setup_Guide_9-23-2020.pdf
Andy2712
Lombard, IL
I just got a Raspberry Pi 4 that I set up my Broadcastify feed on. I'm now trying to get TTD to work on it and I'm having no success. I've tried downloading the 73g version and copying it to the Pi and that didn't work. I've tried following the directions in the manual to the letter and that's not working at all. I can't even get 73g to load. I did finally get 73f to load but I can't figure out how to configure the audio.
I'm brand new to Pi's and I'm not very good with Terminal stuff. I've tried using the Pulse audio GUI and TTD GUI's and nothing is making sense. Is there someone out there that might be able to help me through this. I'm generally pretty tech savy and enjoy figuring this stuff out, but I'm at a loss right now. Thanks!
I'm using the Sabrenet USB audio adapter to feed the scanner audio in and was wanting to use the same audio to feed the TTD for myself.
cpg178
on the TTD main page, you should select the sabrent microphone as your input, and do the same for the scanner
DC31
Massachusetts
SFTP is big when the web host for your files prohibits ftp uploads. I need it for both the audio file uploads and for the redundancy feature. My pi uses rsa keys to secure the connection...
merlin
DN32su
Two Tone is as old as Marconi and so simple, a little logic can decode it. It is nice to see some software that deals with the decoded block.
Maybe consider 5/6 tone like GE-Star or MDC.
WebsterEMA
Howdy. I'm working on setting up TTD with redundancy. Below is the redundant.cfg information. It doesn't seem to be working, so I'm wondering what I'd done wrong. The FTP is a network storage device with FTP enabled. I can connect to it via Windows Explorer and FileZilla. I'm wondering if the problem is something with how the NAS handles FTP, or the fact it's on a folder, rather in the root of the FTP.
[REDUNDANT]
file_access = ftp
tone_tracking_file = CommonToneLogFile.txt
redundant_delay = 30
redundant_instance_alias = Backup on Rocky's
ftp_server = 192.168.10.5/emspager
ftp_port = 21
ftp_username = xxx
ftp_password = xxx
TTD_tracking_file = CommonStatusFile.txt
redundant_down_alert_time = 400
redundant_admin_email = xxx
DC31
Massachusetts
You should be seeing some sort of error message on startup.
look at the beginning of your logfile. Here is what a successful start looks like:
FFMPEG FOUND
pulse selected as audio input device
pulse selected as audio output device
successfully created redundant/PO_StatusFile.txt on ftp.webhost.net
successfully cleared redundant/PO_ToneLogFile.txt on ftp.webhost.net
WebsterEMA
Turned out to be an issue with the radio, not the program or even my computer for once. I have mysterious static zones in my office I wasn't aware of, and it was in one of those. So it didn't trigger the program.
On a different system, a Raspberry Pi I'm trying to get to work, I've got it up and running, and it recognized the tones. But it didn't send the page. I found this section in the Log, and was wondering if the FileNotFoundError could be the problem, and if so how I fix it.
I'm not sure if it matters, but TTD is installed in /home/pi/TTD and in it's audio folder there IS the expected audio file.
Waiting for Silence Webster County EMS 12:44:38 on 05/03/21
Done recording Webster County EMS 12:44:41 on 05/03/21
./audio/Webster_County_EMS_2021_05_03_12_44_23.wav
done writing WAV Webster County EMS 12:44:41 on 05/03/21
done converting to MP3 Webster County EMS 12:44:42 on 05/03/21
done converting to AMR Webster County EMS 12:44:42 on 05/03/21
2021-05-03 00:00:00
2021-05-03 00:00:00
2021-05-03 12:44:42.526186
entry
['Tone1', 'Webster County EMS', 1620063863.4330165, 0]
Traceback (most recent call last):
File "TwoToneDetect73g.py", line 1400, in mail
FileNotFoundError: [Errno 2] No such file or directory: './audio/Webster_County_EMS_2021_05_03_12_44_23.amr'
Email not sent via smtp.gmail.com on port 587 using STARTTLS on attempt 1 trying again in five seconds for Webster County EMS Page Received at 12:44:23 on 05/03/21
Email not sent via smtp.gmail.com on port 587 using STARTTLS on attempt 2 trying again in five seconds for Webster County EMS Page Received at 12:44:23 on 05/03/21
{0: 'bcm2835 HDMI 1: - (hw:0,0)', 1: 'bcm2835 Headphones: - (hw:1,0)', 2: 'USB Audio Device: - (hw:2,0)', 3: 'sysdefault', 4: 'lavrate', 5: 'samplerate', 6: 'speexrate', 7: 'pulse', 8: 'upmix', 9: 'vdownmix', 10: 'dmix', 11: 'default'}
pulse
pulse
Email not sent via smtp.gmail.com on port 587 using STARTTLS on attempt 3 trying again in five seconds for Webster County EMS Page Received at 12:44:23 on 05/03/21
window closed or reloaded,checking for exit criteria in 2 seconds
max retries exceeded, failed to send email
RETURNING AND REMOVING STUFF HERE
[('index.html', <geventwebsocket.websocket.WebSocket object at 0xaafe8b58>)]
Adding Webster County EMS back to detection list after 60.0 second delay
xicarusx
Sayre, PA
That is exactly why it won’t send. the log shows it not being able to find the folder audio inside of /home/pi/TTD
it should exist here
/home/pi/TTD/audio
aaknitt
Are there mp3 files in the /audio folder? If there are mp3 files but not AMR files, it's an issue with ffmpeg. Newer versions of ffmpeg have removed support for AMR, so it needs to be built from source with AMR support included. Steps for doing that are in the TTD setup guide PDF:
cd ~
git clone git://source.ffmpeg.org/ffmpeg.git ffmpeg
cd ffmpeg;
sudo apt-get install libopencore-amrnb-dev
sudo apt-get install libmp3lame-dev
sudo apt-get install libfdk-aac-dev
sudo apt-get install libass-dev
sudo apt-get install libopus-dev
sudo apt-get install libpulse-dev
./configure --pkg-config-flags=--static --bindir=/home/pi/bin --enable-gpl --enable-libass --enable-nonfree --enable-libmp3lame --enable-libopencore-amrnb --enable-version3 --enable-libopus
make
sudo make install
Finally install some required audio codecs:
sudo apt-get install libavcodec-extra58
WebsterEMA
Thank you! I didn't even notice they were MP3's vs the AMR's. They are indeed though, and I appreciate your reply. It's been vexing me so not understanding why it's getting the tones and recording but never sending. One step closer to having all this stuff transferred over to the Pi.
WebsterEMA
I ran the commands you gave twice, and both times I got an error. I didn't pay enough attention the first time, hoping it would work anyways, but it didin't. So I re-ran everything, and got the below response. I'm not sure what all is important, so I've just pasted some in this message, and the rest in the next due to a post length error message I received.
Code:
pi@raspberrypi:~ $ git clone git://source.ffmpeg.org/ffmpeg.git ffmpeg
fatal: destination path 'ffmpeg' already exists and is not an empty directory.
pi@raspberrypi:~ $ cd ffmpeg;
pi@raspberrypi:~/ffmpeg $ sudo apt-get install libopencore-amrnb-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libopencore-amrnb-dev is already the newest version (0.1.3-2.1).
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
pi@raspberrypi:~/ffmpeg $ sudo apt-get install libmp3lame-dev
libmp3lame-dev is already the newest version (3.100-2+b1).
pi@raspberrypi:~/ffmpeg $ sudo apt-get install libfdk-aac-dev
E: Unable to locate package libfdk-aac-dev
pi@raspberrypi:~/ffmpeg $ sudo apt-get install libass-dev
libass-dev is already the newest version (1:0.14.0-2).
pi@raspberrypi:~/ffmpeg $ sudo apt-get install libopus-dev
libopus-dev is already the newest version (1.3-1).
pi@raspberrypi:~/ffmpeg $ sudo apt-get install libpulse-dev
libpulse-dev is already the newest version (12.2-4+deb10u1+rpi3).
pi@raspberrypi:~/ffmpeg $ ./configure --pkg-config-flags=--static --bindir=/home/pi/bin --enable-gpl --enable-libass --enable-nonfree --enable-libmp3lame --enable-libopencore-amrnb --enable-version3 --enable-libopus
install prefix            /usr/local
source path               .
C compiler                gcc
C library                 glibc
ARCH                      arm (armv6)
big-endian                no
runtime cpu detection     yes
ARMv5TE enabled           yes
ARMv6 enabled             yes
ARMv6T2 enabled           yes
VFP enabled               yes
NEON enabled              yes
THUMB enabled             no
debug symbols             yes
strip symbols             yes
optimize for size         no
optimizations             yes
static                    yes
shared                    no
postprocessing support    yes
network support           yes
threading support         pthreads
safe bitstream reader     yes
texi2html enabled         no
perl enabled              yes
pod2man enabled           yes
makeinfo enabled          no
makeinfo supports HTML    no
External libraries:
iconv                   libass                  libmp3lame              libopencore_amrnb       libopus                 zlib
External libraries providing hardware acceleration:
v4l2_m2m
Libraries:
avcodec                 avfilter                avutil                  swresample
avdevice                avformat                postproc                swscale
Programs:
ffmpeg                  ffprobe
Enabled decoders:
aac                     atrac3p                 fits                    mp2float                pcx                     tiertexseqvideo
aac_fixed               atrac3pal               flac                    mp3                     pfm                     tiff
aac_latm                atrac9                  flashsv                 mp3adu                  pgm                     tmv
aasc                    aura                    flashsv2                mp3adufloat             pgmyuv                  truehd
ac3                     aura2                   flic                    mp3float                pgssub                  truemotion1
ac3_fixed               av1                     flv                     mp3on4                  pgx                     truemotion2
acelp_kelvin            avrn                    fmvc                    mp3on4float             photocd                 truemotion2rt
adpcm_4xm               avrp                    fourxm                  mpc7                    pictor                  truespeech
adpcm_adx               avs                     fraps                   mpc8                    pixlet                  tscc
adpcm_afc               avui                    frwu                    mpeg1_v4l2m2m           pjs                     tscc2
adpcm_agm               ayuv                    g2m                     mpeg1video              png                     tta
adpcm_aica              bethsoftvid             g723_1                  mpeg2_v4l2m2m           ppm                     twinvq
adpcm_argo              bfi                     g729                    mpeg2video              prores                  txd
adpcm_ct                bink                    gdv                     mpeg4                   prosumer                ulti
adpcm_dtk               binkaudio_dct           gif                     mpeg4_v4l2m2m           psd                     utvideo
adpcm_ea                binkaudio_rdft          gremlin_dpcm            mpegvideo               ptx                     v210
adpcm_ea_maxis_xa       bintext                 gsm                     mpl2                    qcelp                   v210x
adpcm_ea_r1             bitpacked               gsm_ms                  msa1                    qdm2                    v308
adpcm_ea_r2             bmp                     h261                    mscc                    qdmc                    v408
adpcm_ea_r3             bmv_audio               h263                    msmpeg4v1               qdraw                   v410
adpcm_ea_xas            bmv_video               h263_v4l2m2m            msmpeg4v2               qpeg                    vb
adpcm_g722              brender_pix             h263i                   msmpeg4v3               qtrle                   vble
adpcm_g726              c93                     h263p                   msp2                    r10k                    vc1
adpcm_g726le            cavs                    h264                    msrle                   r210                    vc1_v4l2m2m
adpcm_ima_acorn         ccaption                h264_v4l2m2m            mss1                    ra_144                  vc1image
adpcm_ima_alp           cdgraphics              hap                     mss2                    ra_288                  vcr1
adpcm_ima_amv           cdtoons                 hca                     msvideo1                ralf                    vmdaudio
adpcm_ima_apc           cdxl                    hcom                    mszh                    rasc                    vmdvideo
adpcm_ima_apm           cfhd                    hevc                    mts2                    rawvideo                vmnc
adpcm_ima_cunning       cinepak                 hevc_v4l2m2m            mv30                    realtext                vorbis
adpcm_ima_dat4          clearvideo              hnm4_video              mvc1                    rl2                     vp3
adpcm_ima_dk3           cljr                    hq_hqa                  mvc2                    roq                     vp4
adpcm_ima_dk4           cllc                    hqx                     mvdv                    roq_dpcm                vp5
adpcm_ima_ea_eacs       comfortnoise            huffyuv                 mvha                    rpza                    vp6
adpcm_ima_ea_sead       cook                    hymt                    mwsc                    rscc                    vp6a
adpcm_ima_iss           cpia                    iac                     mxpeg                   rv10                    vp6f
adpcm_ima_moflex        cri                     idcin                   nellymoser              rv20                    vp7
adpcm_ima_mtf           cscd                    idf                     notchlc                 rv30                    vp8
adpcm_ima_oki           cyuv                    iff_ilbm                nuv                     rv40                    vp8_v4l2m2m
adpcm_ima_qt            dca                     ilbc                    on2avc                  s302m                   vp9
adpcm_ima_rad           dds                     imc                     opus                    sami                    vp9_v4l2m2m
adpcm_ima_smjpeg        derf_dpcm               imm4                    paf_audio               sanm                    vplayer
adpcm_ima_ssi           dfa                     imm5                    paf_video               sbc                     vqa
adpcm_ima_wav           dirac                   indeo2                  pam                     scpr                    wavpack
adpcm_ima_ws            dnxhd                   indeo3                  pbm                     screenpresso            wcmv
adpcm_ms                dolby_e                 indeo4                  pcm_alaw                sdx2_dpcm               webp
adpcm_mtaf              dpx                     indeo5                  pcm_bluray              sga                     webvtt
adpcm_psx               dsd_lsbf                interplay_acm           pcm_dvd                 sgi                     wmalossless
adpcm_sbpro_2           dsd_lsbf_planar         interplay_dpcm          pcm_f16le               sgirle                  wmapro
adpcm_sbpro_3           dsd_msbf                interplay_video         pcm_f24le               sheervideo              wmav1
adpcm_sbpro_4           dsd_msbf_planar         ipu                     pcm_f32be               shorten                 wmav2
adpcm_swf               dsicinaudio             jacosub                 pcm_f32le               simbiosis_imx           wmavoice
adpcm_thp               dsicinvideo             jpeg2000                pcm_f64be               sipr                    wmv1
adpcm_thp_le            dss_sp                  jpegls                  pcm_f64le               siren                   wmv2
adpcm_vima              dst                     jv                      pcm_lxf                 smackaud                wmv3
adpcm_xa                dvaudio                 kgv1                    pcm_mulaw               smacker                 wmv3image
adpcm_yamaha            dvbsub                  kmvc                    pcm_s16be               smc                     wnv1
adpcm_zork              dvdsub                  lagarith                pcm_s16be_planar        smvjpeg                 wrapped_avframe
agm                     dvvideo                 libopencore_amrnb       pcm_s16le               snow                    ws_snd1
aic                     dxa                     libopus                 pcm_s16le_planar        sol_dpcm                xan_dpcm
alac                    dxtory                  loco                    pcm_s24be               sonic                   xan_wc3
alias_pix               dxv                     lscr                    pcm_s24daud             sp5x                    xan_wc4
als                     eac3                    m101                    pcm_s24le               speedhq                 xbin
amrnb                   eacmv                   mace3                   pcm_s24le_planar        srgc                    xbm
amrwb                   eamad                   mace6                   pcm_s32be               srt                     xface
amv                     eatgq                   magicyuv                pcm_s32le               ssa                     xl
anm                     eatgv                   mdec                    pcm_s32le_planar        stl                     xma1
ansi                    eatqi                   metasound               pcm_s64be               subrip                  xma2
ape                     eightbps                microdvd                pcm_s64le               subviewer               xpm
apng                    eightsvx_exp            mimic                   pcm_s8                  subviewer1              xsub
aptx                    eightsvx_fib            mjpeg                   pcm_s8_planar           sunrast                 xwd
aptx_hd                 escape124               mjpegb                  pcm_sga                 svq1                    y41p
arbc                    escape130               mlp                     pcm_u16be               svq3                    ylc
argo                    evrc                    mmvideo                 pcm_u16le               tak                     yop
ass                     exr                     mobiclip                pcm_u24be               targa                   yuv4
asv1                    fastaudio               motionpixels            pcm_u24le               targa_y216              zero12v
asv2                    ffv1                    movtext                 pcm_u32be               tdsc                    zerocodec
atrac1                  ffvhuff                 mp1                     pcm_u32le               text                    zlib
atrac3                  ffwavesynth             mp1float                pcm_u8                  theora                  zmbv
atrac3al                fic                     mp2                     pcm_vidc                thp
WebsterEMA
Second half of message from instructions. Still got a length error with the post, so cut out the encoders, muxers and some other stuff. If needed, I'll post it too, but already feel bad doing 2 posts for this.
Code:
Enabled indevs:
fbdev                   lavfi                   oss                     v4l2
Enabled outdevs:
fbdev                   oss                     v4l2
License: nonfree and unredistributable
config.h is unchanged
libavutil/avconfig.h is unchanged
libavfilter/filter_list.c is unchanged
libavcodec/codec_list.c is unchanged
libavcodec/parser_list.c is unchanged
libavcodec/bsf_list.c is unchanged
libavformat/demuxer_list.c is unchanged
libavformat/muxer_list.c is unchanged
libavdevice/indev_list.c is unchanged
libavdevice/outdev_list.c is unchanged
libavformat/protocol_list.c is unchanged
ffbuild/config.sh is unchanged
pi@raspberrypi:~/ffmpeg $ make
POD    doc/ffmpeg.pod
POD    doc/ffprobe.pod
POD    doc/ffmpeg-all.pod
POD    doc/ffprobe-all.pod
MAN    doc/ffmpeg.1
MAN    doc/ffprobe.1
MAN    doc/ffmpeg-all.1
MAN    doc/ffprobe-all.1
LD    ffmpeg_g
/usr/bin/ld: libavformat/libavformat.a(fifo.o): in function `fifo_init':
/home/pi/ffmpeg/libavformat/fifo.c:519: undefined reference to `__atomic_store_8'
/usr/bin/ld: libavformat/libavformat.a(fifo.o): in function `fifo_write_trailer':
/home/pi/ffmpeg/libavformat/fifo.c:624: undefined reference to `__atomic_fetch_add_8'
/usr/bin/ld: /home/pi/ffmpeg/libavformat/fifo.c:631: undefined reference to `__atomic_store_8'
/usr/bin/ld: libavformat/libavformat.a(fifo.o): in function `fifo_thread_write_packet':
/home/pi/ffmpeg/libavformat/fifo.c:188: undefined reference to `__atomic_fetch_sub_8'
/usr/bin/ld: libavformat/libavformat.a(fifo.o): in function `fifo_consumer_thread':
/home/pi/ffmpeg/libavformat/fifo.c:457: undefined reference to `__atomic_load_8'
/usr/bin/ld: libavformat/libavformat.a(fifo.o): in function `fifo_write_packet':
/home/pi/ffmpeg/libavformat/fifo.c:597: undefined reference to `__atomic_fetch_add_8'
collect2: error: ld returned 1 exit status
make: *** [Makefile:123: ffmpeg_g] Error 1
pi@raspberrypi:~/ffmpeg $ sudo make install
INSTALL    doc/ffmpeg.1
INSTALL    doc/ffprobe.1
INSTALL    doc/ffmpeg-all.1
INSTALL    doc/ffprobe-all.1
INSTALL    doc/ffmpeg-utils.1
INSTALL    doc/ffmpeg-scaler.1
INSTALL    doc/ffmpeg-resampler.1
INSTALL    doc/ffmpeg-codecs.1
INSTALL    doc/ffmpeg-bitstream-filters.1
INSTALL    doc/ffmpeg-formats.1
INSTALL    doc/ffmpeg-protocols.1
INSTALL    doc/ffmpeg-devices.1
INSTALL    doc/ffmpeg-filters.1
INSTALL    doc/libavutil.3
INSTALL    doc/libswscale.3
INSTALL    doc/libswresample.3
INSTALL    doc/libavcodec.3
INSTALL    doc/libavformat.3
INSTALL    doc/libavdevice.3
INSTALL    doc/libavfilter.3
LD    ffmpeg_g
aaknitt
Is there anything special that needs to be done in the config file to use SFTP or is at as simple as change the port from 21 to 22? Any changes to the server or username format?
Nothing on the TTD side should need to change except the port number. However, if your server/host uses different login info for SFTP vs. FTP then you may need to make those changes to accommodate.
Andy
