The use of the term "NFM" can be misleading. At one time, it was used on scanners to differentiate it from WFM mode (FM radio, television audio, multiplexing, weather satellites, etc).
Now, the NFM mode setting is available on some newer scanners, such as the Uniden BC250 and BC246, for programming splinter frequencies or agencies that have gone to narrowbanding.
With these scanners, a separate FM mode is also available for programming those agencies licensed under the old channel plans, and still using the wide modulation bandwidth than their narrowband counterparts.
In some cases, you may note an increase or decrease in the volume and clarity of the audio, if you program the frequency in the wrong mode.
I tend to program NFM for UHF and 800 MHz channels, and FM for VHF, but that is not a hard 'n fast rule for me, and I didn't progam the 246 that way.
A couple of occasions that I think warrant the use of NFM:
- when you have two agencies you're trying to monitor that are using frequencies 7.5 kHz (vhf) or 12.5 kHz (uhf) apart
- when you are getting interference from an adjacent frequency on your target frequency
- if you know the agency is operating in a narrowband mode
Jeff Multer
