NMO antenna mount installtion on aluminum F-150
03msc
RF is RF
The Natural State
I can't find my old install notes, but the Comtelco did sweep a bit broader. May have a bit to do with the metal mount and spring size, as well as larger diameter whip.
The whip is thicker than others so that'd make sense.
K7MFC
WRAA720
Phx, AZ
Late to the party (especially regarding roof cross bracket location) but if you go here Body Builder Advisory Service you can drill to structural locations for any ford vehicle.
Thanks for sharing, a lot of useful info there (including where to correctly ground an accessory). I erred on the side of caution and did not drill through any structural members on the roof.
K7MFC
WRAA720
Phx, AZ
A little sneak preview of the work currently in-progress:
A complete install thread in the shack photos forum coming soon...
K7MFC
WRAA720
Phx, AZ
I was worried about the same thing, but the BCD996P2 is readable from the driver's seat - setting the display background color to white makes it the most readable. I suspect the radio that will be installed below it will be a little less readable.
jeepsandradios
East of the Mississippi
One of my coworkers has that with the O9 control head. I rode a bit with him and it was OK, but i can't imagine the O7 or other heads working well. I opted for a top mount console for mine. Works good so far but need more room. My O9 is sitting in a box.
halftime
Utah Cnty, UT
This is the best document to the 2011 superduty. It has all the dimensions, but not the roof structural.
K4RBT
We were supplied a 3/4" hole saw of dubious quality at VSP. I found a 3/4 hole saw in an aircraft tool catalog. This solved all the problems we were having putting antennas in aluminum. You drill a 1/4 inch pilot hole. The saw has a smooth arbor, not flutes. The removable cutter did not have any waves in the teeth and they were 1/8 inch wide. Some people would start cutting at an angle. With this, you put it flat one the sheet and started slow. These things had really sharp teeth and would slice through the aluminum. You measured the hole and it was precisely 3/4" and the antenna base coming up from underneath fit the hole snugly. After I left, I bought my own and it still has the original cutter after 18 years.
