Not Able to Receive P-25 Phase 2 transmissions.
daveo89
Rochester NY
davo89, when dealing with Simulcast, enabling Global Attenuation only on the Simulcast System should limit the number of towers that your radio will receive when scanning this system and will not alter the reception when scanning objects outside
I changed the "Global" setting with no change. Thanks for the suggestion.
daveo89
Rochester NY
  • CDAT.zip
Whistler_Support
Whistler Representative
Bentonville, Arkansas
Daveo89, I see several little things that I wish to point out.
You mentioned that the conventional channels are working however this configuration file contained no conventional frequencies. Were these removed recently?
I noticed you have scanlist 11, 12, 13, and 14 enabled, but your scan set only encompasses scanlists 1 - 10.
With the scanset of 1-10, the unit will ignore objects assigned to scanlists outside the listed scanset even if enabled.
Regarding the Monroe/Ontario Counties P25 system, Monroe South has LCN 4, 5, 6, 7, 8, and 9 locked out.
Regarding the East Site, the Data Threshold Low should be 88 and I see you have this set to 75
I did not see Attenuation applied to the Monroe/Ontario Counties P25 system in question (maybe you just tested this briefly with the ATT button instead)
You also have a Monroe/Ontario Counties Motorola Trunking system without any talkgroups entered. I could not find this system when reviewing the radioreference database. Can you elaborate?
I would recommend that you look over and address the items mentioned above, then we can begin making small changes only to the system in question to see if there is improvement.
daveo89
Rochester NY
I think I sent the wrong file. No! I did send the wrong file. I made some of the changes you suggested and am running the radio. I'm not seeing much difference though. I copied the file from the radio and here it is.
  • CDAT.zip
Whistler_Support
I will review and let you know if I spot anything on the Monroe P25 system.
Give me a bit to run some tests.
btw, I see that your DMR Trunked system LCN frequencies are not grouped together, you may want to correct this as I do not know how the unit will perform on this DMR system with 0.00000 positioned between several of the LCN frequencies.
daveo89
Rochester NY
I'm just happy for you and the other's here taking the time out to try to help me out.
Whistler_Support
It seems you did not set the Radio ATT to Global and as a result the Attenuation you set to "Global" on your specific P25 system was ignored. This would result in no change which you have confirmed.
For the scanner to respond to individualized Attenuation selections, you must set the scanner to show the letter G along the top line of the LCD. This tells the scanner to apply Attenuation only any individual object that has the Attenuation box checked or to any system that has the Attenuation set to Global.
If setting this using the scanner keyboard, be sure you do not select GA as this will attenuate everything in your configuration regardless of the Attenuation box status.
To cycle thru these settings on the radio, you can press and release the ATT button, otherwise you can use EZ Scan to change the Attenuation Settings of Attenuation Mode from Normal to Global then write the configuration to your scanner.
Do not change the Global Attenuation On/Off selection as this will apply Attenuation to ALL objects and this is not what you want.
daveo89
Rochester NY
I got the Global Att set and reloaded the program in to the radio. I had it running this evening. The "G" is on the top line of the scanner display now but unfortunately, the P-25 stations are still not making it. Thanks again for the help.
Mason69
Carthage, Tennessee
I'm in Rochester NY, Monroe County and the public safety went to the P-25 phases 2 system. Since then and with much downloading and tinkering with my radio, TRX-1, I am at a brick wall. I can receive all the conventional channels with out any problem. But nothing on the P-25. I also noticed that when I am running the "Whistler Control" program, the P-25 frequencies show that they are "muted". Not locked out but muted. I had tried to find what would do that in the radio and the program but to no avail. If anyone has any idea what could help me out, I would be forever in your debt. Thank you.
They are more than likely simulcast. If not, try changing your thresholds. Or DAC gain. Ive seen that work before even though it just supposed to ve a audio control.
daveo89
Rochester NY
This saga has ended. With the help of the people who responded to my needs and a week long interaction of a "Whistler Support Rep" who got me in the right direction, I have gone as far as I can go at this point. The Whistler support rep and I narrowed it down to an attenuation issue. Everything from the stock antenna to a paper clip was tried with the paper clip working rather well. But the rep also suggested a "Banana clip to BNC" connector along with a stubby antenna. They both worked OK. I am now able at least, to receive the transmissions. But simulcast distortion is a big problem. With the transmissions I do receive, probably only 20% of them are understandable.
From there, I "Thank" everyone who took the time out of their day to help me out. I learned a lot more about my radio than I did before. I'll still keep trying to find out if I can get it to decode more transmissions with taking it in to the field and playing around with it and everything I learned here. Thanks again.
19-685
Listening on a CRM-114 Discriminator
Try THRESH LO to 10% and THRESH HI to 99% for the site(s) which are difficult to receive.
NOTE: for systems with only one SITE, you'll need to do this manually.
Your mileage may vary...
