I should have clarified that I was speaking of colloquialisms and the terminology is not technically correct.Actually, OFT is not conventional, it is trunking. Conventional is conventional.
Mr. Upman,
I reiterate my question with the outmost respect for you and for uniden,
- Does Uniden is planning to work on fixing this issue ? (and is it fixable) ?
If the answer is negative, I will simply get rid of the SDS100-SDS200 and return to my two 536 and get another 436
Can you get logs using the SDS and BCDx36HP side by side? These use the same methods/code for these functions, so it is unusual that they would have different results.Results of my tests using the Global Filter in AUTO and NORMAL mode.
As usual: exact same conditions, programming and external antenna
BCD536HP and SDS200 running simultaneously - Data collected with Proscan
Note: system 42.04 is NXDN Trunking should not have been there but kept anyway.
My 536hp file #2 was running simultaneously with the SDS 200 if it helps.Can you get logs using the SDS and BCDx36HP side by side? These use the same methods/code for these functions, so it is unusual that they would have different results.
So you want lots of videos demonstrating simultaneously the 536 and 200 (as I did in the short example on youtube below) ?Can you get logs using the SDS and BCDx36HP side by side? These use the same methods/code for these functions, so it is unusual that they would have different results.
If so I can provide hours if it will help
SDS200 RSSI was too low for reliable reception was all we could tell from it.
Ok..it appears they reviewed log file #2 on the SDS200, saw the signal was weak (it isn't very strong, it's a 20 watt NXDN system 1 mile away), but both files were recorded simultaneously and the 536 was receiving and decoding it. I'm assuming they stopped after seeing signal strength and didn't review both files in their entirety?I don't have the tools to review log files. Engineering reviewed them. If the signal is weak, sometimes it will work and sometimes it won't.
Both 200 and 536 are on debug files on the same systems -Video is nice, but debug file is needed for engineering review. Even video isn't quite useful, as it does not show RSSI, Noise, Frequency, or D-Error.
What I find interesting is under the NXDN TGID it doesn't show one but in the couple one channel NXDN systems I monitor, it comes up TGID 0. One of my earlier posts I was wondering if that's the issue...scanners were inconsistently ignoring TGID 0?My understanding is to the effect that as soon as we activate the "Debug Log to SD Card" function, it becomes impossible to track the number of hits with Proscan (both using WiFi or with the Cable) and the recording function ai also desactivated.
Therefore we submit Debug File for analysis without knowing the number of transmissions that were missed by the SDS200.
Can someone confirm please ?
In the meantime, here's my log from this morning, we can clearly see what was missed by the SDS200
.View attachment 69320View attachment 69321View attachment 69322
Hi Werinshades,
The problem is not related to the signal; these transmissions are all from the same systems on both machine
This morning only, there are 723 transmissions missing on the SDS200 (57%)
BCD536: 1276 transmission
SDS200: 553 transmission
