Yeah I ment unless your doing digital audio only. I sat at the forman shop and they have a mag mount ant on the siding of the roof... lolModulation should be NFM. Digital threshold should be Auto.
If you set audio option to digital, the Wait Time setting is ignored. It is only used if you set the audio option to All (both digital and analog).
Railroads generally use low power and directional antennas aimed along the tracks, so unless you are close to the tracks or using a directional antenna, you probably aren't going to get a clear signal. You can only hear the talking defect detectors and trains if they are within 5 miles or so with a handheld or mobile antenna, even on analog.
Neighbors trx receives it strong and clear
Are you trying to receive the Tn D7 NXDN system? I have hand programmed the sites along the Tn River and plan to do testing Friday to see how it works. I will post back.
No such thing as "AUTO" for the audio type. ALL, ANALOG, or DIGITAL.
Hello Scanner friend. Can someone use baby talk for me and tell me what i should be doing for this upgrade i have now read about ? NXDN Support Comes to the BCD436HP and BCD536HP?????
i use the sentential software on my mac, think i updated that system, and it didn't cost me a thing. why am i reading that it says 30$ on Uniden website????
what am i missing ? and what is a NXDN?
thanks sir, but what is it????????
No problemthanks sweetheart
Try Googling it. There is plenty of info on NXDN if you bother to look.
The trx is just simple stock antenna
My 536 is connected to discone 10ft above roof
Now since my 436 is now updated does that mean the Sentinel will have the the NXDN Systems to import?
Sent from my iPad using Tapatalk
No as stated at the beginning of the thread. NXDN is not supported in Sentinel yet you have to program it by hand for now. That's why the introductory price is 30 dollars and will go to 60 when supported. All that being said Proscan has been updated for NXDN.Now since my 436 is now updated does that mean the Sentinel will have the the NXDN Systems to import?
