NXDN Upgrade for BCD436HP and BCD536HP Now Available!
rescue674aa
I’m an idiot
How do you view the LCN order on the 436?
rescue674aa
I’m an idiot
Yeah I saw that..but need LCN order Radio isn’t working right on a NX4800 system
rescue674aa
I’m an idiot
Yeah but after it completes what i do then?
Sent from my iPad using Tapatalk
jasonhouk
Marion, Ohio
UPMan,
you can import it from another software and then read it with Sentinel?
Current version of Sentinel does not support NXDN. Per UpMans post be careful not to overwrite a manually entered in system.
Houk
Sent from my Moto G (4) using Tapatalk
enosjones
Price, Utah
So when I got the DMR upgrade I was Happy about the Fact that if I searched the bands in the "Search for" option it would mute the control data channel and give me site and system info and even let me hear the talk groups, however on this NXDN upgrade I search the bands and it doesn't do that , it has to be programmed as at least a conventional channel before it will start decoding. Including if I turn on digital only in the search options. Is there a way to maybe add this feature, like what DMR does? U can identify SysID and Site ID info much faster if your searching and it stops and decodes it, especially if the system isn't in the RRDB yet, and especially in big cities where a lot of systems are going digital...
Sent from my iPod touch using Tapatalk
UPMan
In Memoriam
Arlington, TX
Yes, that is the current operation. Woodpecker keeps pecking that we should not do that, but instead skip it entirely.
jonwienke
More Info Coming Soon!
VA
My solution is to use ProScan to log, and automatically lockout a channel if it hangs the scanner for more than 1 minute. Best of both worlds.
VA3DBJ
Ontario Database Admin
Is anyone else having issues scanning 9600 systems? Trying to scan the Mobile Business Communication system in Toronto and it seems to be having some trouble. Missing a lot of comms, if not most, compared to DSD+. Seems to have issues in conventional mode as well. LCN finder is also having some issues, even though there are a lot of comms occurring.
There are no issues with 4800. Picking up QueOn network with no issues.
UPDATE: had to put the site into manual FM and set digital threshold mode into manual as well, with a setting of 7/8. Now tracking fine.
VA3DBJ
u2brent
OAMPT
KRWDPAXKRS1
Sentinel NXDN programing
You CAN use sentinel to edit TG's and Unit ID's in a NXDN TRUNK SYSTEM.
The trick is to create the system and sites manually in the radio. Also add sites, add frequencies with LCN's if known and assign RAN/AREA if known. Create a DEPT and add 1 TG dummy if unknown.
Verify that you have it all correct and working.
Then read from the radio. The system will say P25 in Sentinel never mind that. You can then add TG's and RID's. Just leave the detailed site stuff alone in Sentinel (you can edit names & QK's & Num Tags)
Then after updating TG's/Site Names/Departments if desired. you can rewrite the updated FL to the radio and it should still work as NXDN.
Not for the faint of heart but you can directly edit the hpd file using notepad as well.
system 8108 hpd file code..
TargetModel BCDx36HP
FormatVersion 1.00
Trunk Fleetcall NXDN 4800 Off Nxdn On Off Auto Ignore Srch 1 1 0 Off Off Ignore Off Off On Decimal
DQKs_Status On Off Off Off On Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off Off
UnitIds 6 11 6 Off Auto Off On
UnitIds 65520 1506 Trash 65520 Off Auto Off On
Site (FC01) Washington/DC On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 1
T-Freq Off 0 1002 RAN=1
Site (FC02) Booths Corner/Delaware PA On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 2
T-Freq Off 463306200 669 RAN=2
T-Freq Off 501462500 1012 RAN=2
T-Freq Off 451200000 33 RAN=2
T-Freq Off 451425000 69 RAN=2
T-Freq Off 461400000 442 RAN=2
T-Freq Off 0 1011 RAN=2
Site (FC03) Philadelphia/Philadelphia PA On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 3
T-Freq Off 506337500 0 RAN=3
T-Freq Off 506700000 0 RAN=3
T-Freq Off 506975000 0 RAN=3
T-Freq Off 507900000 0 RAN=3
Site (FC04) Theodore/Cecil MD Off 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 4
T-Freq Off 451225000 37 RAN=4
T-Freq Off 452325000 213 RAN=4
T-Freq Off 453000000 321 RAN=4
T-Freq Off 463456200 693 RAN=4
T-Freq Off 463725000 736 RAN=4
Site (FC05) Frederica/Kent DE On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 5
T-Freq Off 461637500 402 RAN=5
T-Freq Off 462100000 476 RAN=5
T-Freq Off 463400000 684 RAN=5
T-Freq Off 461387500 440 RAN=5
Site (FC06) Millsboro/Sussex DE On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 6
T-Freq Off 451787500 127 RAN=6
T-Freq Off 452237500 199 RAN=6
T-Freq Off 463300000 668 RAN=6
T-Freq Off 463825000 752 RAN=6
T-Freq Off 464587500 874 RAN=6
Site (FC07) Federalsburg/Caroline MD On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 7
T-Freq Off 0 0 RAN=7
Site (FC08) Smyrna/New Castle DE On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 8
T-Freq Off 463693700 731 RAN=8
Site (FC09) Towson/Baltimore MD On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 9
T-Freq Off 451018700 4 RAN=9
Site (FC10) Wyndmoor/Montgomery PA On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 10
T-Freq Off 462737500 1021 RAN=10
Site (FC11) Bethesda/Montgomery MD On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 11
T-Freq Off 0 0 RAN=11
Site (FC12) Wilmington/New Castle DE On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 12
T-Freq Off 0 0 RAN=12
Site (FC15 Unknown/DE NJ?) On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 15
T-Freq Off 454425000 0 RAN=15
Site (FC16) Waterford Works/Camden NJ On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 16
T-Freq Off 461425000 0 RAN=16
Site (FC17) Unknown/NJ? On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 17
T-Freq Off 0 0 RAN=17
Site (FC18) Unknown/NJ? On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 18
T-Freq Off 0 0 RAN=18
Site (FC19) Tinton Falls/Monmouth NJ On 0.000000 -0.000000 0.0 AUTO Circle Off 400 Auto 8 19
T-Freq Off 451043700 8 RAN=19
T-Group All Fleetcall TG's Off 0.000000 -0.000000 0.0 Circle 0
TGID 11 ? Off 11 ALL 17 2 0 Off Auto Off On 1 Off Any
TGID 30 Trash Off 30 ALL 17 2 0 Off Auto Off On 2 Off Any
TGID 52 ? Off 52 ALL 17 2 0 Off Auto Off On 3 Off Any
TGID 64 ? Off 64 ALL 17 2 0 Off Auto Off On 4 Off Any
TGID 80 ? Off 80 ALL 17 2 0 Off Auto Off On 5 Off Any
TGID 81 ? Off 81 ALL 17 2 0 Off Auto Off On 6 Off Any
TGID 82 ? Off 82 ALL 17 2 0 Off Auto Off On 7 Off Any
TGID 83 ? Off 83 ALL 17 2 0 Off Auto Off On 8 Off Any
TGID 85 ? Off 85 ALL 17 2 0 Off Auto Off On 9 Off Any
TGID 100 Delaware City Refinery Off 100 ALL 17 2 0 Off Auto Off On 10 Off Any
TGID 200 ? Off 200 ALL 17 2 0 Off Auto Off On 11 Off Any
TGID 502 Home Nursing Off 502 ALL 17 2 0 Off Auto Off On 12 Off Any
TGID 600 J Berrios ? Off 600 ALL 17 2 0 Off Auto Off On 13 Off Any
TGID 700 ? Off 700 ALL 17 2 0 Off Auto Off On 14 Off Any
TGID 862 ? Off 862 ALL 17 2 0 Off Auto Off On 15 Off Any
TGID 900 ? Off 900 ALL 17 2 0 Off Auto Off On 16 Off Any
TGID 911 ? Off 911 ALL 17 2 0 Off Auto Off On 17 Off Any
TGID 916 ? Off 916 ALL 17 2 0 Off Auto Off On 18 Off Any
TGID 917 Dynamic Therapy ? (03/29/2018) Off 917 ALL 17 2 0 Off Auto Off On 75 Off Any
TGID 920 ? Off 920 ALL 17 2 0 Off Auto Off On 19 Off Any
TGID 921 Pivot ? Off 921 ALL 17 2 0 Off Auto Off On 20 Off Any
TGID 922 ? Off 922 ALL 17 2 0 Off Auto Off On 21 Off Any
TGID 923 Pivot ? Off 923 ALL 17 2 0 Off Auto Off On 22 Off Any
TGID 930 Taxi Off 930 ALL 26 2 0 Off Auto Off On 23 Off Any
TGID 931 ? Off 931 ALL 17 2 0 Off Auto Off On 24 Off Any
TGID 932 ? Off 932 ALL 17 2 0 Off Auto Off On 25 Off Any
TGID 933 ? Off 933 ALL 17 2 0 Off Auto Off On 26 Off Any
TGID 936 ? (03/29/2018) Off 936 ALL 17 2 0 Off Auto Off On 27 Off Any
TGID 939 Dynamic Therapy Off 939 ALL 17 2 0 Off Auto Off On 28 Off Any
TGID 1101 ? Off 1101 ALL 17 2 0 Off Auto Off On 29 Off Any
TGID 1102 BAYSD ? Off 1102 ALL 17 2 0 Off Auto Off On 30 Off Any
TGID 1103 ? Off 1103 ALL 17 2 0 Off Auto Off On 31 Off Any
TGID 1401 ? (03/28/2018) Off 1401 ALL 17 2 0 Off Auto Off On 32 Off Any
TGID 1500 Trash ? Off 1500 ALL 17 2 0 Off Auto Off On 33 Off Any
TGID 1501 Trash ? Off 1501 ALL 17 2 0 Off Auto Off On 34 Off Any
TGID 1502 Trash Residential Service Off 1502 ALL 17 2 0 Off Auto Off On 35 Off Any
TGID 1504 Trash ? Off 1504 ALL 17 2 0 Off Auto Off On 36 Off Any
TGID 1505 Trash ? Off 1505 ALL 17 2 0 Off Auto Off On 37 Off Any
TGID 1506 Trash Recycle Service Off 1506 ALL 17 2 0 Off Auto Off On 38 Off Any
TGID 1507 Trash ? Off 1507 ALL 17 2 0 Off Auto Off On 39 Off Any
TGID 1818 WM ? Off 1818 ALL 17 2 0 Off Auto Off On 40 Off Any
TGID 2018 ? Off 2018 ALL 17 2 0 Off Auto Off On 41 Off Any
TGID 2206 ? Off 2206 ALL 17 2 0 Off Auto Off On 42 Off Any
TGID 3201 ? Off 3201 ALL 17 2 0 Off Auto Off On 43 Off Any
TGID 3244 ? Off 3422 ALL 17 2 0 Off Auto Off On 44 Off Any
TGID 17000 Concrete Off 17000 ALL 17 2 0 Off Auto Off On 45 Off Any
TGID 17001 Colonial Airport Park & Ride Shuttle Bus Off 17001 ALL 26 2 0 Off Auto Off On 46 Off Any
TGID 17003 ? Off 17003 ALL 17 2 0 Off Auto Off On 47 Off Any
TGID 17200 Chichester SD Buses Off 17200 ALL 32 2 0 Off Auto Off On 48 Off Any
TGID 17300 ? Off 17300 ALL 17 2 0 Off Auto Off On 49 Off Any
TGID 19000 Medical Svc Off 19000 ALL 17 2 0 Off Auto Off On 50 Off Any
TGID 19001 ? Off 19001 ALL 17 2 0 Off Auto Off On 51 Off Any
TGID 21002 Airport Shuttle Off 21002 ALL 26 2 0 Off Auto Off On 52 Off Any
TGID 21101 ? Off 21101 ALL 17 2 0 Off Auto Off On 53 Off Any
TGID 21150 ? Off 21150 ALL 17 2 0 Off Auto Off On 54 Off Any
TGID 21176 Trash ? Off 21176 ALL 17 2 0 Off Auto Off On 55 Off Any
TGID 21201 ? (03/29/2018) Off 21201 ALL 17 2 0 Off Auto Off On 56 Off Any
TGID 21300 Trash Off 21300 ALL 17 2 0 Off Auto Off On 57 Off Any
TGID 21301 Primecare Medical Transport (Milford DE) Off 21301 ALL 26 2 0 Off Auto Off On 58 Off Any
TGID 21500 Wallingford-Swarthmore SD Buses Off 21500 ALL 32 2 0 Off Auto Off On 59 Off Any
TGID 21600 ? Off 21600 ALL 17 2 0 Off Auto Off On 60 Off Any
TGID 22000 Delaware Electric Cooperative Off 22000 ALL 34 2 0 Off Auto Off On 61 Off Any
TGID 23000 Towing Off 23000 ALL 17 2 0 Off Auto Off On 62 Off Any
TGID 23001 ? Off 23001 ALL 17 2 0 Off Auto Off On 63 Off Any
TGID 23002 ? Off 23002 ALL 17 2 0 Off Auto Off On 64 Off Any
TGID 24000 Dumpster Svc Off 24000 ALL 17 2 0 Off Auto Off On 65 Off Any
TGID 25604 ? Off 25604 ALL 17 2 0 Off Auto Off On 66 Off Any
TGID 27000 Taxi (Lewes Rehoboth Dewey Area) Off 27000 ALL 26 2 0 Off Auto Off On 67 Off Any
TGID 27500 ? (03/31/2018) wknd Off 27500 ALL 17 2 0 Off Auto Off On 76 Off Any
TGID 28010 ? Off 28010 ALL 17 2 0 Off Auto Off On 68 Off Any
TGID 28246 ? Off 28246 ALL 17 2 0 Off Auto Off On 69 Off Any
TGID 28350 ? Off 28350 ALL 17 2 0 Off Auto Off On 70 Off Any
TGID 33000 ? Off 33000 ALL 17 2 0 Off Auto Off On 71 Off Any
TGID 36000 ? (03/31/2018) wknd Off 36000 ALL 17 2 0 Off Auto Off On 77 Off Any
TGID 47542 ? Off 47542 ALL 17 2 0 Off Auto Off On 72 Off Any
TGID 50001 PennSTAR Ch1 Disp (155.385) Off 50001 ALL 4 2 0 Off Auto Off On 73 Off Any
TGID 53794 ? Off 53794 ALL 17 2 0 Off Auto Off On 74 Off Any
D
DaveNF2G
Guest
AFAIK, the problem with the Sentinel workarounds for NXDN entry and editing will still require full creation of the system in Sentinel again after NXDN support is added to the software.
Sentinel is unable to change a trunked system type, and it appears that the scanners cannot do it either. It is so fundamental to the system that it is not editable. If you want a new system type, then you have to create a new system.
So if Sentinel stores your NXDN system as P25, you will not be able to just change it to NXDN later. And if Sentinel uploads the system to your scanner as P25, you won't be able to change it in the scanner, either.
u2brent
OAMPT
KRWDPAXKRS1
:roll:If you read my post..Sentinel does NOT store it as a P25 System!!. It only displays as one in Sentinel. The Flag that tells the radio what type of system is STILL in the FL. (You can verify this by opening the hpd file with notepad. Note the nxdn trunk type to the right of the system name. Also note the Freq CH & RAN are saved as well) [hence the example shown in my original post]
YOU WOULD NOT HAVE TO RE-CREATE A NEW SYSTEM WHEN SENTINEL IS UPDATED. IT WILL JUST SHOW NXDN AS NXDN NOT P25 AS IT CURRENTLY DOES AND THE SITE CH#/LCN AND RAN WILL DISPLAY AS EXPECTED
I have already performed this operation and can verify it works!
If you don't understand; Then just wait for Uniden to update the software.
Sentinel can't change a System that is created, but you can do it manually with notepad.
Also If you properly created the nxdn system using the radio then read it off the radio Sentinel does not revert it back despite the confusing (to some) display.
Happy Resurrection Day!
