NXDN Upgrade for BCD436HP and BCD536HP Now Available!
rescue674aa
I’m an idiot
Thanks for the reply Enos..I will try another way and then read it in Sentinel thanks
Sent from my iPad using Tapatalk
rescue674aa
I’m an idiot
Well i have the Info for the System here in Florida so I guess just need to find a way to import it
WX4JCW
Stow, Ohio
As Jon said Proscan works really well
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
pratzert
I've purchased the key and entered it in the scanner (dashes and all), and I'm getting a message that says "Incorrect key entered. Press any key." I've re-entered the key three times and received this message each time.
It's been a while since I've upgraded my '436 (DMR was the last one), but I can't think of anything I'm doing wrong. We're not supposed to enter the "Checksum" info, are we?
I have a 436 and purchased the NXDN key.
I kept getting the same error message when I try to enter the key.
***Never Mind**** I figured it out...... Thanks.
Had to move the curser over to the next field.
pratzert
Don't hit E between digits.
Thanks Pau.
I was making hat mistake instead of moving the cursor over to the next field.
DUH ! My bad.
I have managed to successfully upgrade my 436 with Provoice/Dmr/NXDN.
I'm Sooooooo looking forward to getting the SDS100 !
vocoder
Indiana
What nxdn squelch setting is everyone using, external antenna vs indoor antenna?
Also seems squelch setting has to be much tighter with nxdn vs p25
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
I have not ever changed my squelch settings from 2 on any of my x36s and never changed the digital fine tuning from the default settings (Auto & 8 IIRC). All digital audio has sounded fine.
One 536 is on the stock back of set antenna, one 536 is on a Spectrumforce magmount (thru a Stridsberg multicoupler), and the 436 most often lives connected to an Austin Spectra mounted on my truck's fender.
Voyager
That would be due to receiver desense from a strong local signal, or a bad coax connection somewhere, not poor antenna performance. Especially with 3 different antennas.
Nope. Heliax tests fine and works on other antennas. No strong TXs around on VHF and none that are moderately close that are on the air full time.
The Discone has no gain at all. Antennas with 6 dBd of gain work well.
rescue674aa
I’m an idiot
UPMan,
you can import it from another software and then read it with Sentinel?
Voyager
When will sentinel upgrade the NXDN and will it cost us an additional $30.00 at that time?
Do you mean another $30 over what you paid? They don't do that with PV or DMR, so I would imagine the Sentinel will still be free.
If you mean another $30 if you buy it then vs buying it now, likely yes. UPMan has stated that the discount is with the understanding that the SW is not yet available.
soberone14
Spotsylvania,VA
I'm not that good at importing from other software any help would be appreciated or I can just wait. Thank you in advance
