BXW,The audio should be better after making a few adjustments. Also some temporary antenna changes were made to improve the signal, comments are welcome. The internet feed has some issue (loud whine) emitting from the digital radio, so audio is muted until the issue can be worked out.
I monitored a few transmissions today in Upper Southampton and Warminster. The signal strength looks to be about 1 bar higher than yesterday, but the audio remains noisy and somewhat low. Hope this helps. I am using a PRO-106 with the RS 800MHz antenna. If I use my attic mounted ground plane at home reception is better, of course. But either way, it is clearly down than from before the switch over.
