BillVette
I just had a transmission from zone 9 and it was loud and clear.
Ben,Some questions:
1. Are the old UHF fireground frequencies and the UHF Fire Police repeater going to be available post switch? I know some companies have dualband APX gear because they have their own UHF channels. So, I was wondering if these should remain in the database for now.
Yes, those four new frequencies will be the main fireground channels off the system. I was not sure if the old 500MHz channels would be maintained for anything or those are dead like the old TRS.Ben,
At 3:15 pm today, I heard Temple Med helo calling a Bucks unit on FG1 (501.3375). I noticed in the database that there are four new 700 MHz Fire Direct channels listed (North, South, East, Central). No traffic heard yet this afternoon on the Central Fire Direct. Maybe they are replacing the two 500 MHz Fireground 1 and 2 channels????
The audio should be better after making a few adjustments. Also some temporary antenna changes were made to improve the signal, comments are welcome. The internet feed has some issue (loud whine) emitting from the digital radio, so audio is muted until the issue can be worked out.Confirming 155.250 very weak into Warminster. Hopefully they can clear the problem soon. Central Fire just migrated to the new system. I can hear the roll call on 155.250, but as I said, very weak audio.
Agreed!! I can't say this enough. Kudos to our Bucks Commissioners for their foresight in refusing to encrypt the entire system in spit of pressure from the police chiefs. The commissioners get it...an informed public is an asset to emergency services.When we migrated to P25 Phase II here in Central Florida, all law enforcement agencies immediately implemented full time encryption on every talkgroup they use, which is why I started my C.A.R.E. Group. As a result, I have a great deal of respect for the Bucks County Board Of County Commissioners in making a fair and balanced decision regarding public radio access.
The new system is a SIMULCAST system so the same signal is coming from every tower. What you describe is the classic LSM issue - your radio can't discriminate the same signal arriving from more than one place, so you get drop outs. It is a big problem for many people with the new Phase 2 simulcast systems, especially those who are close to multiple towers. Listen to the North Band Philly Fire feed on RadioReference and you will hear the same problem. Tons of missed transmissions.This may be a post for a "fresh" thread, but as it concerns current vs former performance of Bucks' system, I'll put it here, since its a sticky and where others in my situation may go first.
I seem to be an exception to the rule--I went from having pretty good reception/performance on the old 500 MHz system, to it being absolutely atrocious on the new 700 MHz system. I have my 20+ year old Bearcat 560XLT in the room, hear an (obviously) analog Bucks fire dispatch, yet the digital simulcast hardly ever kicks on, and if it does, its half way through the dispatch (I've the system lock on--its ONLY scanning the 700 MHz system right now). If I go back into scan, I get analog Bucks dispatch just fine, MontCo, etc.
I'm using a 436HP that is connected to an attic mounted antenna that performed quite nicely with the 500 MHz system, and still works great with Montgomery County's 800 MHz system, yet I'm hardly grabbing anything at all. I'm located in Upper Southampton--its not like I'm trying to listen from rural Berks or something, though I am located in the LOS to Ivyland valley along Davisville Rd. My programming is up to date, as is the scanner's firmware, and I can confirm I haven't locked anything out. Has anyone else out there seen a performance degradation as I have, and if so, what did you do to resolve it, assuming you did?
Are you able to get closer to Bucks to test it? Plymouth Meeting may be a little to far out for a 700MHz system. You didn't give any details on your antenna, but it sounds like you were mobile so antenna may be an issue, especially if you were just using the rubber ducky.I should be able to pick this system up from Montco shouldn't I? I went up to Plymouth Meeting today with my Pro 668 & didn't hear a thing from the new system. Tried downloading from the SD card library as well as from the Pro 668 software, two different banks, all have the most up to date database (437). Also tried downloading control channels only & all channels. Is there anything else I should change or tweak to be able to pick this system up? I've had no issues in the past picking the old 500mhz system. Any help would be appreciated
Ya, I tested using RS telescopic (20-006) & 800 mhz (20-283) antennas. I'll make a trip up to Bensalem some time and testAre you able to get closer to Bucks to test it? Plymouth Meeting may be a little to far out for a 700MHz system. You didn't give any details on your antenna, but it sounds like you were mobile so antenna may be an issue, especially if you were just using the rubber ducky.
