OFFICIAL MSWIN Thread
INDY72
Indianapolis, IN
Only the dispatches will be clear from what I hear. Tac 1 thru 5 car 1 thru 5 swat 1 thru 5 will be encrypted. Detectives should also be encrypted
Sent from my LG-K330 using Tapatalk
riccom
My wife and kids said i have to many radios!
Yankton, South Dakota
What about amr, are they leaving the 800 band and sticking to the same system
Scanning is a tool to know what is not seen, and what not is seen to be heard.
riccom
Guess it is time to buy the other sdr dongle
INDY72
Indianapolis, IN
Arm has their DMR encrypted system but may also get an simulcasted tg.
INDY72
Indianapolis, IN
Someone run pro96com on all hinds area sites and nab those 2 new towers and the new Clinton and Hinds TGs
riccom
I can with unitrunker or dsd plus
INDY72
Indianapolis, IN
From the submissions I have worked it looks like Simpson County is fully coming on the MSWIN for comms. Is the Simpson County E-911 LTR TRS still in use? If so, is SO, and the PDs simulcasting on it and MSWIN?
INDY72
Indianapolis, IN
It's the term from cellular communications and is basically the same thing. LWIN even takes it further with Suitcase Sites!
Cell On Wheels
Cells on wheels (COW), or site on wheels,[1] are telecom infrastructures, placed on trailer approved for road use, towed by heavy goods vehicles for loads of up to 3500 kg. These mobile radio base stations guarantee full operation in just one day and in restricted spaces. COWs provide fully functional service, via vehicles such as trailers, vans and trucks, to areas affected by natural disaster or areas with large user volume, such as major events. The backhaul to the network can be via terrestrial microwave, communication satellite, or existing wired infrastructure.
Mobile radio base stations with flanged pole are mobile support structures composed of a special trailer with retracting stabilizers approved for road use. The antenna supporting pole, with climbing ladder up to the summit, is fixed to the main base frame and it is composed of cylindrical flanged sections integrated by two or three sets of guys with a standard height of up to 20 meters. The flanged pole mobile station, installable in eight hours, does not require civil works or foundations, and is complete of lateral ballast concrete weights and a working platform in checkered plate.
MFTR: Cell on wheel with flanged pole, placed on trailer approved for road use
A rapid deployment self-mounting pole is a mobile supporting structure corresponds to a special two-axle trailer with telescopic stabilizers approved for road traffic. The antenna supporting pole, with standard height of up to 20 m, is made of aluminium and consists of three telescopic tubular elements. Installation is easy and fast, and is carried out with manual winches.
MTUC: Compact self-mounting pole
Another RDU is a mobile cell site with self-mounting pole; that can be towed by heavy goods vehicles for loads of up to 7500 kg. The antenna supporting pole, with a standard height of up to 20 m, is made of aluminium and consists of three telescopic tubular elements. Installation is easy, fast and is carried out by means of manual winches.
MTCO: mobile cell site with self-mounting pole
Mobile station on trailer is a mobile stations with telescopic mast are portable structures, towed by heavy goods vehicles for loads of up to 12000 kg. The antenna supporting pole, with a standard height of up to 30 m, is made of steel and consists of three telescopic tubular elements. Installation is easy, fast and is carried out with manual or electric winches.
INDY72
Indianapolis, IN
Clinton should be off the SOW actually since the FOA Road and other new sites should be online by now unless they had delays of some kind. Which SOW is in Clinton now?
INDY72
Indianapolis, IN
Foa was the hinds county site correct?
Sent from my LGMS345 using Tapatalk
One of them yes. At least 2 of them are supposed to be converts to MSWIN per MWCC minutes. And last I knew, both sites were close to being finished with Hinds and Clinton jumping online on the SOW, and other sites knowing they would not have full coverage until the new sites were online and powered up in WAT mode. FOA road has an multi system site.... It has one of the Hinds County TRS sites, an Federal site, State DPS VHF High, Low, and UHF ants.... The only Hinds County site with more RF flowing is most likely the WJTV site lol.
