Official PRWN Talkgroups Thread
Scott_PHX_APP
Phoenix AZ, Gilbert
Hey Guys,
Been some time since I've been on here, and I mostly listen to the Railroads and ATC, but does anyone know what frequency SRP uses for their comms to the work crews? I have a PRO-95 and seems like just after I got it, all the Gilbert Fire and PD went to digital, such is my luck, but I was wondering if SRP might still be basic analog?
Thanks in advance...
Later...
Scott_PHX_APP said:
Hey Guys,
Later...
Hi. This would probably be better suited in a seperate thread, but oh well.. Per the SWFD9, they are on VHF//UHF as well as a TRS (EDACS). Here is what is listed:
Litchfeild - 143.5300
Countywide - 153.6050
Line Maintenence - 153.6200
Phoenix - 153.635
Audio / Data controls - 153.710
Paging - 158.1900
Irrigation South - 451.200
Irrigation North - 451.2500
And theres a few different tower sites.. the best for you since ytou are in Gilbert would be the Chanlder frequencies (938.1250, 938.8875, or 938.800). I'm not really sure, but can a pro 95 pick up EDACS?
Hope that helps
-Dylan
sniperbob
Does anyone actively listen to Gilbert or Mesa PD?
I was listening to Mesa PD last night and heard a search going on with the canine units, this was on the District 4 channel (3009), which should have been on a hot channel. maybe the switched the channels around.
Are "event" channels the same as "hot" or "chase" channels.
And on Gilbert are the detail channels the same as the normal patrol channels?
thanks, many things have changed since listening to vhf.
Scott_PHX_APP
Phoenix AZ, Gilbert
Sniperbob,
I might be inclined to listen to them if I had a 96 or something other than my 95, but alas, that's not the case. I would also like to listen to Gilbert Fire but they too, from what I understand, are in the digital world now also. That said, I did program the SRP frequencies above and I did find a few more I need to enter, but so far, I get more comms on the high band stuff for now. I programed the EDACS channels and I thought I would see the talk group numbers displayed when I received something on those frequencies, but it, (the 95) just shows "ED: none" and nothing else. I even noticed the voice levels are lower on the 900mHz frequencies I programed? I'm guessing I'm not programing things right so I got a few things to figure out I'm sure... :confused:
Later...
Scott_PHX_APP
Phoenix AZ, Gilbert
AZ,
Thanks for the info. I thought Mesa was TRS? Someone told me they, (Gilbert Fire) was using the new TRS system along with Mesa and GPD? I guess I'll dig up the Mesa fire frequencies and have a listen...
The "chase" channels you mentioned. Are you refering to a TRS or channels that they use for calls?
Thanks for the info...
BTW, would you know why I don't see the ID's for the EDACS system on my 95?
Later...
PS. If I should start a new thread on this, just say so...
sniperbob
Mesa Fire (which dispatches Gilbert and Apache Junction) are all digital, luckily Phoenix still uses vhf, which makes it so the only way for the 2 (systems) to talk to each other is through a patch, which in our case four channels that I know of are patched through vhf.
154.340
154.235
153.950
154.280
Scott_PHX_APP
Phoenix AZ, Gilbert
Sniperbob,
Thanks for the info on the Mesa stuff. I was pretty sure that Mesa and Gilbert were digital and it would figure, I got my Pro-95 about 2 weeks before I know they were going digital... Go figure... Anyway, I'll slap in the 4 freq's you mentioned and see what I get. Thanks again for the info.
Later...
sniperbob
You should get everything. The only channels that aren't patched through are a few more tactical channels and some training channels.
InlandAZ
Maricopa AZ
154.340
154.235
153.950
154.280
Are there any tones associated with those frequencies? I had all but one of them (with CT/DC freqs specified). The one I was missing was 154.280.
sniperbob
By tones do you mean the ring before a unit is dipatched?
154.280 is a mutual aid channel, you can hear the helicopter pilots. ;)
InlandAZ
Maricopa AZ
CTCSS tone - sorry.
ICP963
Chandler, AZ
There is no PL Tone used on 154.280 usualy, or there shouldn't be. That way they don't have to worry if someone has no tone in their radio and can't hear when htye need to.
mike_webb59
New Braunfels, TX
RE: BC796D and Band Plans
This is a cross-post to a Q I've posted in the Uniden Scanner thread.
The BC796D allows for one to set one of four Band Plans along with CC Mode. But there is legalese that basically says some work, some don't , try it out.
Is anyone monitoring PRWN with a 796 and are you using CC/Band Plan.
Does it matter based on what system you are using. I'm trying to hook onto 101 in the 17/Dunap area.
Thanks, Mike
AZScanner
Somewhere in this room. Right now, you're very col
Mike,
DO NOT use CC only mode on the 796 for P25 systems. All you need to do is set it for Motorola 800Mhz trunking and program in just the control channels. The scanner automatically determines the voice channel from the data stream. Setting a CC mode will confuse the scanner and you will miss comm's. Found that out the hard way. :D
-AZ
bigjstud1108
Maricopa, AZ
I was wondering if anyone could help me fill-in the gaps, and also identify the unidentified talk group ID’s, and maybe add any that may be missing from my list.
Simulcast D Mesa/Gilbert
867.12500, 867.30000, 867.42500, 867.60000,
867.67500, 867.75000, 867.82500, 867.90000,
868.05000, 868.20000, 868.27500, 868.35000,
868.50000, 868.52500, 867.25000, 867.10000
Mesa Talk Groups
Deck A
03005 HOT CALLS
03000 A1 DOB Dispatch
03003 A2 CEN Dispatch
03006 A3 FAL Dispatch
03009 A4 SUP Dispatch
03012 A5 FUTR Dispatch
A6 SPCOPS
03036 A7 EVENT 1
03037 A8 EVENT 2
03038 A9 EVENT 3
03039 A10 EVENT 4
03040 A11 EVENT 5
03041 A12 EVENT 6
03042 A13 EVENT 7
03033 A14 BS-1 Tac
03034 A15 BS-2 Tac
03017 A16 INQR-1
Deck B
03001 B1 DOB Tact
03004 B2 CEN Tact
03007 B3 FAL Tact
03010 B4 SUP Tac
03013 B5 FUTR Tac
03002 B6 HOT CALLS
03016 B7 SUPV Tac
03022 B8 WARNTS
03045 B9 PARK RANGER
03044 B10 FD Link
03064 B11 FD Dispatch link
03046 B12 Municipal Security
03219 B13 UTILITIE
03031 B14 EMMG 1
03032 B15 EMMG 2
03018 B16 INQR 2
Deck C
C1
C2
C3
C4
C5
03027 C6 SWAT 1
03028 C7 SWAT 2
03029 C8 SWAT 3
03030 C9 SWAT 4
03019 C10 CID 1
03020 C11 CID 2
03021 C12 CID 3
03023 C13 SID 1
03024 C14 SID 2
03025 C15 SID 3
03026 C16 SID 4
Deck D
D1 MCSO Link
03220 D2 SARVR
D3 DPS Link
D4 TMPE Link
03049 D5 GLBRT Dispatch link
D6 CHDLR Link
03222 D7 ASU PD Link
03107 D8 AJ PD Link
D9 PHX PD Link
D10 SCDL PD
D11 GLND PD
03224 D12 PERI
03225 D13 PNCO SO
D14 FUTR Link
D15 FUTR Link
D16 DNRG
Gilbert Police Talk Groups
Deck A
03049 A1 DISPATCH
03050 A2 INFO/RECO
03051 A3 HOT CALLS
03052 A4 DETAIL 1
03053 A5 DETAIL 2
03054 A6 CAR TO CA
03056 A7 INVEST
03057 A8 SWAT
A9
A10
A11
03058 A12 SEARCH
03059 A13 EVNT 1
03060 A14 EVNT 2
03061 A15 EVNT 3
03062 A16 EVNT 4
Deck E
E1
02874 E2 PS 1
02973 E3 PS 2
02872 E4 PS 3
02871 E5 PS 4
01799 E6 PS 5
01798 E7 PS 6
01797 E8 PS 7
03228 E9 PS 8
03229 E10 PS 9
03230 E11 PS 10
02870 E12 COMN 1
02869 E13 COMN 2
01796 E14 COMN 3
03231 E15 COMN 4
E16
Mesa Fire Talk groups
03064 F1 DISPATCH
03065 F2 TACTICAL
03066 F3 TACTICAL
03067 F4 TACTICAL
03068 F5 TACTICAL
03069 F6 TACTICAL
03070 F7 SAFETY
03071 F8 RESCUE
03072 F9 FIRE/OPEN
03044 F10 SUPV TAC
03055 F11 PD/FD LI NK
Other Talk groups heard on Simulcast D
01761 Encrypted
02913
02920
02949
02954 Encrypted
02960 Phoenix PD TAC-8 800 South Valley Chase/HOT (rotated with Tac-4)
02962 Phoenix PD TAC-6 600 North Valley Chase/HOT
02963 Phoenix PD TAC-5 500 Central Valley Chase/HOT
02964 Phoenix PD TAC-4 400 South Valley Chase/HOT
02996 Phoenix PD 400A South Mountain Precinct Patrol
02997
03076
03081
03104
03108 AJ PD LINK TO TAC 2 (not confirmed)
03705 Utilities
03722
03727
03732 Utilities
03733
03734 Utilities
03735 Mesa City Services
03738
03739
03741
03742
03744 City services
03813
03811 Library
03814
jambo
Phoenix, AZ
Hello PPL,
Here lately I have been hearing alot of activity on the following TG's,
3107
3108
I haven't had the chance yet to narrow it down to which agency it is, but I believe it's Apache Junction PD running on Mesa's P25 system.
