Ohio Area Military Communications
In a house along a busy road in Mercer County, Far
Ohio National Guard...
While running around the Buckeye State on Tuesday, April 5th I was hearing the ONG on TG 2016. They were throwing out the call signs Rough Rider, Trans 01 and Trans 02. Seems like Rough Rider was the base or command canter and Trans 01 and 02 were transport buses. They were talking about arrival, departure and number of packs. Also heard some transmissions about "meet you at the rest area in a few". Meaning maybe they were on the move getting somewhere for training. I started pick up the TG while going south on I-71 around the 169mm and continued hearing it down into the Middletown area on I-75 at the 32mm. On my way back north along the same route I also heard the same type of transmissions. I started hearing them around 9am and last word I heard was at about 8:30pm.
jsoergel
Cincinnati/Dayton, OH
RHINO 50 (C-17A, 93-0604?) airborne and preparing for flyover of the Dayton Dragons game, TOT 1900L. Comms with Patterson Tower on 126.900 and ground spotter at the stadium 289.400.
jsoergel
180th FW this afternoon....
STING 51 (2x F-16C, 90-0704/90-0706)
STING 61 (2x F-16C, unid)
STING 71 (2x F-16C, unid)
SLUFF 62 (KC-135R, unid)
SPACE 69 (Atterbury JTAC)
All flights inbound:
317.625 or 360.675 > 290.500 > 316.125 > 343.800
139.625 (STING 51), 139.975 (STING 61)
STING 51:
316.125 > 290.500 > 317.525 > 383.300 > 350.225 > 360.775
STING 61/71:
316.125 > 290.500 > 353.750 > 288.300
139.625 Aux 6
139.975 Aux 7
288.300 ZID Rosewood Low
290.500 ZID Pike Low
317.525 ZID Madison High
317.625 ZID Dayton High
316.125 ZID Pike Discrete
343.800 Buckeye AR
350.225 ZID Shelbyville Low
353.750 ZID Lytle Low
360.675 ZID Appleton High
360.775 ZID Muncie Low
383.300 Atterbury Range
Note: I never found the A/A for STING 71 while inbound. Once in Buckeye, 71 said his aux radio was inop.
jsoergel
Bold Quest 11 begins Monday (August 22) and runs through September 23. I'll try
to tweet what I hear (@jsoergel949 or #ohmilair), but any additional input is
greatly appreciated.
Here are some frequencies to monitor (all AM unless noted):
Atterbury Range (R-3401, Racer MOAs):
30.100 (FM) ANG Range Tower [SEC]
32.300 (FM) Medevac
38.900 (FM) Range Control [PRI]
41.900 (FM) Range Control [SEC]
118.600 Columbus Tower
126.200 Atterbury UNICOM
138.250 ANG Range Tower [ALT]
244.400 Area South Discrete
248.500 Area North Discrete
259.400 ANG Range Tower [ALT]
265.500 Admin Freq
383.300 ANG Range Tower [PRI]
Jefferson Range (R-3403, JPG MOAs):
138.950 Jefferson Range
343.000 Jefferson Range
379.400 Jefferson Range [ALT]
Muscatatuck Urban Training Complex (MUTC):
139.600 Grizzly Ops
236.150 Admin Freq
For reference:
Resources - Notices - FAA - FAASTeam - FAASafety.gov
jsoergel
C-5A 70-0457 left Patterson today on its final flight to AMARG. This is technically the last C-5 they had (69-0003 is in flyable storage at KCEF and will be retired soon).
Youngstown - Warren
Does anyone listen to the 910th AW out of this airport? I pick up very little while over in that area. I can't say that I have ever heard any of the 141's or 130's that are doing touch downs. I have done searches for MilAir and programmed in the frequencies from the database. If anyone has any info throw it out here for all to see. Mostly I just hear "Aircraft Maintenance CH 1". I have the NAC for that freq. also. It's 293. Also Security shows a NAC of 293 but I have not really heard anything that sounds like security.
OHIOSCAN
Lorain Cnty, OH
YOUNGSTOWN WARREN RAP (KYNG)
910th AW C-130
CALLSIGN:"VADER"
(VADER 22,)
118.250 CLR
119.500 TOWER
238.825 BATTLESTAR OPS (11)
263.000 TWR.(119.5)
275.800 GRND.(121.9)
276.000 VADER A\A
298.950 A\D(CLE-120.775)
322.300 A\D(133.950)
381.400 A\D(120.200\128.250)
392.200 A/A (11)
910th AW C-130
CALLSIGN:"VADER"
(VADER 22,)
118.250 CLR
119.500 TOWER
263.000 TWR.(119.5)
276.000 VADER A\A
392.200 A/A (11)
Okay, there are a couple here not listen in the database. You should submit them to be entered. I will put them in and see if I can pick up anything more then I already don't, so to speak. Thanks for the info.
digitalanalog
United States of America
I had a hit on 119.500 (tower) yesterday at 6:38pm (EST) several times.
had several other scanners running at that time and by the time i got them all turned down
there was no more transmissions, but I was able to hear the tower and it was loud and clear, will continue monitoring...
digitalanalog
I copied traffic again
119.500 (tower) at 8:15am (EST)
119.500(tower) at 9:27am (EST)
238.825(battlestar ops) at 9:31am (EST)
All traffic was loud and clear
Uniden BCT15
ST2 Antenna @(only) 20'
GRE Amp 3001 (base model) 20db gain (full open)
I was sure I would never hear anything from them, I am way down in a whole at my location, at 20' antenna height,it's barely over my house top and surrounded by 60-80' tall tree's. I am Very Surprised..
jerk
jerkville
119.500 is air plane to tower and is not the actual tower com.
Youngstown Regional Airport and has nothing to do with the air wing mil air
But it does, Mil-Air will use the frequency just like all the other traffic in and out. The UHF tower freq and perhaps os,me of the other will have the same traffic as found on VHF as the tower is often simulcast.
digitalanalog
Agreed, I have listened to Vadar to tower many times, still cannot receive any ground coms from anyone, my location and lack of good antenna will leave me in the dark as far as ground coms go until I get that fixed. Can't wait for Spring to get here.
jmsanders83
KC8JSU
Germantown, WI
You may also want to keep an eye on 384.7. This used to be the main Vader/Battlestar frequency for many years in AM mode. A few years back when I still travelled through this area frequently, they moved to 238.825 AM for main ops and started using 384.7 in FM mode with a CTCSS of 156.7. At the time, it seemed like they were using 238.825 AM for Air to Air and 384.700 FM for Air to Ground.
nodak1crdet3
Detroit, MI
Toledo CAP up right now, 07-05-12.
There is a Combat Air Patrol over Toledo OH for the Presidential bus tour through Ohio.
MUDDY 11 & 12 (TOL F-16's)
228.900 HUNTRESS 12:55pm. MUDDY 12 has a Standby Gen failure.
128.625 Cleve.C. 01:02pm. We were given the Toledo low, 01:02pm.
260.900 HUNTRESS, 01:03pm. What’s the ETA for our replacements, 01:05pm.
134.350 TOL app, RTB, 01:15pm. FALCON? 01, 01:28pm.
MUDDY 13 & 14 (TOL F-16's)
128.625 Cleve.C. 01:06pm.
260.900 HUNTRESS, as fragged, 01:07pm. MUDDY 13 is noses cold, 01:39pm. Copy pre contact one mile trail, 01:39pm.
2/4542 NOTAM Details
rdale
Lansing, MI
Toledo's F-16s are headed to Dayton for the airshow - any idea what freq's I might program in for them?
