stillline1979
@wgbecks
I have a 10k resistot soldered onto the disc line at the input pin of the 3.5mm jack. Should I be changing the value of this resistor?
@KA1RBI
Thanks again for all your help. I took your advice and experimented with some different USB sound cards and did get some slightly better results. I think you are correct in assuming that something on the signal path is the issue.
@KA1RBI
