Ottawa P25
VE3RADIO
Planet Earth
Cool.. I will pump this system in to my scanner and give it a whirl.. is it phase 1 or 2?
DaveH
Ottawa, Ont.
Phase I at the moment though the radios are Phase II capable. Content is not
terribly interesting right now. I think it is live testing using non-critical operations.
Audio sounds "swishy" which is not unusual for the PSR600, but wonder if
they are using simulcast (LSM) which might partially explain it.
Dave
DaveH
Ottawa, Ont.
Listening to the radio in the morning, waiting for garbage to be picked up, what a treat... :)
I looked down on one of the trucks and noticed the antenna was changed from the
loaded gain type to a regular black 1/4 wave whip, an indication of which vehicles in
what departments have been converted.
Dave
mmisk
Ottawa Canada
Ottawa P25 Signal
Is it just me or does this system have some sort of technical problem?
The CC seems to be transmitting a considerable amount of noise along with it's signal.
I have very good signal strength here,
Also, 866.7875 is constantly transmitting a tone using P25, and this transmitter seems to be transmitting a lot of noise also. (signal is strong)
It does not look like a proper signal.
EDIT: I just noticed that the modulation is showing as: CQPSK. Reading about this now.
DaveH
Ottawa, Ont.
P25 CC's "sound" noisy when you listen on an FM receiver; it's normal, depends on the data
being transmitted, wouldn't worry as long as it decodes OK. Listen to Gatineau on 866.7625,
866.9125 etc. or RENIR VHF CCs for comparison.
The tone on 866.7875 is a test signal (getting NAC 293), has been taken out of
rotation, again not a big issue.
Dave
DaveH
Ottawa, Ont.
I cant even get the control channel from inside my house in the west end.
Like the present system there will be multiple sites. Depends how far west you are.
CC may not be up to full power yet. Only TG 2017 and 2018 heard as of late.
BTW the site shown as 1 is actually site 2; so where is site 1 (?).
Dave
VE3RADIO
Planet Earth
I found three more sites..
866.1875 - West tower getting 100% signal even in basement.
867.0375 - 1 bar in house.. 4 outside.
863.7375 - 1 bar in house..
All results on a 436 with rubber suck.. not setup to do unitrunker to confirm sid or anything but these frequencies dont show as gatineau or cassidian in the db.
DaveH
Ottawa, Ont.
Cassidian is now known as Airbus DS Communications. Don't rely on the RR DB for this
one. Check TAFL, shows 863.7375. Gatineau uses 867.0375.
Dave
DaveH
Ottawa, Ont.
Also interesting to note, Unitrunker and DSD+ won't decode the strong CC I hear.
PSR600, and Pro96com hanging off it seems to work. I wonder if it has to do with
this being a Harris P25 system, not Motorola.
Dave
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Edit: Misunderstood the correlation of this to Ottawa P25
mmisk
Ottawa Canada
Decode the CC with UT
"Also interesting to note, Unitrunker and DSD+ won't decode the strong CC I hear.
this being a Harris P25 system, not Motorola." (From Dave)
Dave, I finally was able to make UT decode the CC. I have my antenna on a rotor and if I carefully adjust the direction UT will decode with a health of no betterthen 60 (if I am lucky) despite a very strong signal.
Mike
Edit: Sorry my attachment is huge, but the original image size is: 5.5 X 4.87 in.
