P25 Concord
KM4WLV
Rockwell (Rowan County), NC
In Concord this evening and found a new one -
7122 - CABROW
CABROW is used for Rowan County units in the Kannapolis and Enochville area to be able to talk back to Rowan Communications because the Salisbury TRS doesn't get good coverage that far south right now. It was also used as a "mutual aid" type TG between Rowan & Cabarrus units back in the day before the fleetmaps supported the different county TG's.
KD4UXQ
Can't seem to get the BER down
I am experirencing a high Bit Error rate on the decoding of this system with a BCD396XT. I have the system programmed by downloading it into Free Scan. I have a full receive signal strenght in several locations but a high BER almost all the time. Any ideas what may be wrong with any programming?
Thanks,
Harold
KM4WLV
Thanks,
Harold
Harold I use FreeSCAN as well. If you want to email me a copy of your programming file and let me look at it. My reception is flawless for the Concord system on my 396XT. Matter of fact I can pick it up in my house on the northwest side of Salisbury using just a stubby 800 antenna.
I'll be happy to get it fixed up for ya !!
I'm going to send you my email address in a private message.
EDIT - I can't send you a PM so email it to me at : daniel(dot)michael(at)carolina(dot)rr(dot)com
kd8x
NC
Thanks,
Harold
Harold try this. I have the 396xt also...when downloaded from the DB with Freescan you will notice that it has this system listed as a Mot type 2/p25 system.....change that to a P25 standard system. Not Moto...it will help decode much better I have found. Let me know what you find out....
KM4WLV
That's a good tip !! I should have thought about that but I've been a bit frazzled today lol
KD4UXQ
Thanks, Daniel. I've been tied up for the last day and haven't been able to send you anything I'm going to try the suggestion from KD8X and let you know how it works out. If not I'll take you up on your offer.
-Harold
KD4UXQ
Thanks for the tip! I'll let you know how it works out as soon as I am able to try it.
KM4WLV
No problem Harold. The last response about changing the system type is a good idea. If you have it set to Mot Type II/P25 instead of a P25 Standard it won't decode at all correctly.
Try that out and if it doesn't work then just shoot that over to me and I'll fix it for ya !!
epepperjr
feeling dumb here
Guys -I just bought a 396xt and have been trying to program it and it is killing me. I am an EXTREME novice, but love listening - It was easy to program in 800mz now i feel like a fish out of water - HELP
KD4UXQ
Working better. What I had originally downloaded had it set to Mot type 2/p25. I was adding a few new TGs as they were being listed here. But over the weekend I downloaded the system again just to get all the recent updated TGs since there were so many new ones, and now it is set for P25 Standard which works much better.
trumpetman
Charlotte, NC
Download FreeSCAN and make purchase a programming cable if you haven't already. I'm working on a basic file for starters that I'll send out in the next day or so.
trumpetman
Charlotte, NC
Just got a good chunk of the file done. Those with digital Uniden scanners (supported by FreeSCAN) are more than welcome to email me for the file. Right now it has EMS & Fire talkgroups for the P25 systems in Mecklenburg, Union, Cabarrus, & York. Once I get most everything completed, then I'll put it up on the forums (to prevent constant updating).
My email is my username (at) radioreference (dot) com
KM4WLV
Chris,
Thanks for doing this. I had offered and was going to work on it today but got covered up with something else.
kd8x
NC
I saw talkgroup 7013 come up yesterday but not sure who it was although I think it is Concord PD...kinda out of sequence with 7014 being main disp....
KM4WLV
7013 = Cabarrus Sheriff ATG (Announcement TG)
I could tell what agency by listening to the numbers, as well as a few voices on it. Also confirmed by someone in the know with Cabarrus Sheriff.
kd8x
NC
Thanks for info
I submitted the following today...
CCSO ATG 7013
CCSO-TAC6 7005
KM4WLV
Thanks for info
CCSO ATG 7013
CCSO-TAC6 7005
Thank's for getting that submitted bud. I forgot to do it and by the time I realized that you were on it. Many thanks to you for monitoring the new leg of 2D0 and getting those submissions in ! :D
