Peel Region
farmboy
burlington,on.canada
Good Evening!I downloaded Peel Region to ARC 250 and downloaded to my 250 scanner. It won't accept Trunk "ON" in the software and "save"it keeps going to "OFF"any suggestions? Thanks.
mikewazowski
Forums Manager
Oot and Aboot
Have you setup the bank in the trunk system settings to let the software know that the bank is 800Mhz Type II?
farmboy
Yes I have this on the same bank as London/Woodstock OPP.Trunking is set "ON" and "Saved" but Peel willnot stay on!Thanks for your help!
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Your OPP bank would be VHF.. and as Mike mentioned Peel is 800 Moto II
Put Peel in a different bank on it's own with the appropriate details and see if that corrects the problem.
mikewazowski
Forums Manager
Oot and Aboot
Still not sure what you are trying to do by sticking two trunk systems in the same bank.
Waterloo Region is an edacs system and Peel is a Motorola Type II. You will be able to select trunking for all 800Mhz frequencies now but you will only be able to listen to one system at a time.
If you get within range of Waterloo, you will need to change the system type over to 800Mhz edacs and make sure you have the frequencies in the right lcn order.
