If the scanner is not working with a known good file, there is a good chance that the internal adjustment is needed. I did some checking and found it to be VR3 for the Pro-2096. Do you agree? I programmed a Pro-96 for a firefighter and it would not receive the P25 system at all. I performed a complete alignment using professional test equipment with the same results. It wasn't until I detuned VR4 about 1 KHz that the scanner worked.I suspect that the pro2096 might have drifted and is receiving off-frequency. If this Is the case, there is an internal variable resistor that would need to be adjusted.
TEST the receiver, plug in your weather freq.can i pickup
Indiana Project Hoosier SAFE-T
Project 25 Phase 1 with this scanner?
this scanner is saying it picks up p25.. but programed with win96 and arc96 and nothing picks up? any help please
I think it has been rebaneded can I put it back to stock?TEST the receiver, plug in your weather freq.
Do you hear the weather service ?
Has the scanner been "Rebanded" ?
So I need to change to the rebound table in the 2 pictures?Check this out:
Scanners not working after rebanding.How to fix.
Can no longer pickup Marion/Granty County Sheriff radio traffic I live in the southern part of Marion IN. 46953. This morning Nov. 16th my radio shack scanner was working fine , picking up both Marion Police and Grant County Sheriff radio traffic. However, this evening my scanner is not picking...forums.radioreference.com
Yea not sureThis is interesting:
800 MHz Rebanding
Ahhhh, rebanding. What's all the fuss about? Put simply for scanner users it could be a headache for some. Keep in mind that rebanding wi...iscanner.blogspot.com
