So, if you've seen my other noob posts, i've been playing with a Radio Shack pro-97 scanner. It's fun (When you get something to listen in on). But I need a little bit of clarification. I had Radio Shack program Washington County on it, thinking i'd get alot of things to listen to. But i'm not. So, a few questions.
1) What frequencies are good to listen in on, and do they use the trunk system? So far, with it programmed, the only one I found interesting was 855.96250. And when I hold the button to "hold ID", i'm not sure that it does anything.
2) Would I be better off just getting it programmed for Hillsboro? Or Beaverton? Every once in awhile "Tigard PD" or "Hillsboro PD" will come up on that bottom line. I usualy trunk on Hillsboro (On that 855.96250 channel above) and sometimes it's okay.
3) What means what? What does "mot: <number here>" mean? Is it the officer-spacific ID, and if so, what does MOT stand for? What does "Wash Co TRS" stand for? I get the Washington County part, but what is TRS?
I don't know why, but my mind is drawing a blank. I know I have a couple more questions, so will reply as I come across them. In the mean time, thankyou for the patients with me guys.
Thank you kindly!
Thank you kindly!
