program pro-197
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
yungchin said:
1 is gonna disappear if i press it! that i know,but its not gonna take care my problem about turning on and off scan list.
When the 1 disappears, that scan list has been disabled (or turned off), which means it is not being scanned. The same thing applies to all 20 scan lists, as they are enabled and disabled.
yungchin
waco tx
im still stuck on this scan list stuff! i read the manual,but it don't seem like it told me much about turning scan lists off and on.
yungchin
waco tx
okay someone said when i press 1 that scan list disappear! okay what about when the new 800mhz frequencies i programmed in list 2? how come when i press 1 to disappear and press 2 and turn the 2list on it said's nothing enable?
yungchin
waco tx
programming pro-197
okay how come when i press 1 to make scan list 1 disappear and scan list 2 said nothing enable so i program some 800mhz frequencies in scan list 2 okay how come when i finish programming the 800mhz frequencies in scan list 2 it still said nothing enabled?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
You either programmed the 800MHz freqs in another list or you failed to save list 2 after programming them. Don't you know how to check?
fmon
Eclipse, Virginia
krokus gave a clear description in this post.
And I gave another clear description in this post.
Prior to 1 disappearing did you see OFF at right side of line three on display?
Did you see the off or on on display as you press 1? If so, isn't that clear enough?
fmon
Eclipse, Virginia
In the Index pages on page 123 of owners manual find Scan Lists. Page 41 is best example to indicate what we mean regarding Enable and Disable. The other pages indicate scanlist membership. As mentioned above, it could be you don't have anything programmed (or Mapped) to scanlist 2
yungchin
waco tx
yeah you right about i already had the 800mhz frequencies in scan list 1 so when i press the button to make scan list one disappear and tried to program those same frequencies in scan list 2 it still said nothing enabled! i kinda figure that had something to do with me already having the 800mhz frequencies in scan list 1! but i think i do pretty good on the save part though.
yungchin
waco tx
programming pro-197
okay why when i cleared out all the freqeuncies in scan list one and put the frequencies in scan list five it still said nothing enabled in scan list 5? and why the frequencies i put in scan list 5 are still showing that the frequencies are still in scan list 1 when i cleared the frequencies out of scan list one?
fmon
Eclipse, Virginia
Does a * appear next to Scanlist 5 when you programmed the freqs? If not you failed to program list 5 correctly To get the * at list 5 press SEL
yungchin
waco tx
programming pro-197
okay now i got it! thats what i was missing * now i hit sel and now it said's *05 and that took care the problem.really thank you for your help very much.
yungchin
waco tx
programming pro-197
alright i figure out everything i needed to know about how to program the pro-197 with you guys help! i could'nt made it without ya.happy thanksgiving to everybody who help me out and all scanner monitors.
krokus
I'm glad to hear that you're figuring out the scanner. I still suggest using software, it is much easier.
fmon
Eclipse, Virginia
Happy Thanksgiving to you also. :D
I agree with krokus. ;)
yungchin
waco tx
programming icom r75 receiver
one of my radio buddies died a year or so ago and his wife sold me his icom 75 receiver,but i don't know how to program it or nothing. i wish i knew more about that radio. its in very good condition his wife sold it to me for 60 dollars. its almost like new.
texasemt13
CenTex DBA
Hunter, TX
That question would be valid in the iCOM Receivers Forum. Post questions about iCOM receivers there.
Be sure to start a new thread with your question by clicking the "New Thread" button in the middle-left above the "Announcement" threads.
We have Forums for just about any topic related to radio (List of Forums).
yungchin
waco tx
pro-197 digital scanner
that just like zob-tinpusher now a couple of months ago i went in a pawnshop here and purchase a pro-197 digital scanner that is almost brand-new for 69dollars.well at radio shack here pro-197's are still 3hundred 99dollars to this day.but the point is,yeah i knew what the scanner was worth,but the guy at the pawnshop said they wanted 69dollars for it and that's what i give them 69dollars.if the blessing is for you trust me you will receive.
