Programming D04 Dilemma
mikelemmen
Kalamazoo, MI
I have a Dash Mount Astro Spectra Analog Mid Power
Programmed by someone else
Service Mode says;
R110103
A070309
CNTLHD31
D04JKF9PW5AN
494AAw0613
1MEG
FLSHCD 000004-000004
I am using aftermarket cable and RIB. The cable is put together properly.
This radio works in the car and can transmit fine, no problems, no error codes.
Computer is an old Gateway with XP and a serial port.
Now, here is the fun part. I am trying to read the radio and make some changes to it but the software doesn't seem to work. I'm using 011001 to program in DOS using Freedos on a USB, I can program other radios with the DOS stick like my HT1000. The program will read the radio and comm test fine but will stop at the end and give some obscure error code that I can't find online.
Here is the question; Where did I go wrong? Software Version?
Any help at all would be appreciated
KG4INW
Midlothian, VA
What exact software are you using? If you're using old Spectra RSS, it won't work. You need Astro Spectra CPS which will run just fine as a Windows XP program (DOS RSS was available for the AS but CPS is easier).
mikelemmen
Kalamazoo, MI
I've tried RSS R01.10.01 (this one could communicate with the radio)
I tried higher RSS but they just reboot the radio and give a comm error.
What would you recommend for a CPS (number)? Does it have to be below r11.xx.xx because of the radio's firmware being 11.xx.xx
KG4INW
Midlothian, VA
Astro Spectra CPS R05.03.00 was the last version released and should work just fine with any revision of firmware. Again, runs under Windows XP and since you have a real serial port, you should be good to go.
