programming HELP!!
figgman
I an trying to program my radio and our department has 2 channels for our fire ground one goes to the repeater and the other is a talk around channel which does not go to the repeater it is only line of sight. on our frequency listing it is 49 and 49 t/a with only one frequnecy. does anyone know how to program the radio so it does not go to the repeater?
Duster40
Texas, Lubbock area
Ah....what kind of radio do you have ????
YOU know what you have...
the rest of us have no idea of what you
are trying to program !!
figgman
sorry a vertex standard vx-350 i didn't think it mattered i thought maby i had to enter a slightly different frequency but i dont think so.
Blue Mound
In order for the radio to go through the repeater it must have the offset frequency. Meaning if your frequency is 154.445 and its off set is 154.010. (the recieve is 154.445, and the transmit is 154.010) it will go through the repeater. if you add channel 2 as 154.445 as both the transmit and the recieve with the same PL/DPL tone as your rereater channel it will not hit the repeater.
repeater: Talkaround:
RX:154.445 RX:154.445
TX: 154.010 TX:154.445
PL:100.0 PL:100.0
Hope this helps.
P.S. or you can program one of your aux buttons (if applicable) to enable talk around. that would free up a channel in your radio.
