OK - doubt this is a ProScan issue but I am running ProScan when it happens and hoping for a solution. The SDS200 is connected to my LAN via cable. I have POOR internet service through Ziply - period - on and off like a 4yr old with a light switch. But I do have an internal WIFI - printers, NAS, etc. that run well regardless of internet connection. If I am connected on my WiFi internal network and or if internet is up I can fire up ProScan and listen to my SDS200 on my internal WiFi. My issue is during some of these "blips" of internet service. ProSscan/scanner lose the connection and I am unable to use the scanner unless I physically turn the scanner off/on. (Proscan says unable to connect and I cannot restart with the software.) Again I am not blaming ProScan, but more wondering why the internet loosing it's connection makes ProScan/scanner lose connection on my internal WiFi. Aren't ProScan and the scanner separate from the internet and should not be affected on internal WiFi?
Hoping for some insight to what might be causing the issue or.... I'm doomed to live with the scenario.
Thanks -
Thanks -
