The last post I saw said that was in the works. I think some people have been hacking at it but not sure that would be a good idea for the regular user. Then I may be wrong and missed a post.
As far as I know, it's not in the works but rather is fully functional.
Can someone tell me what or how to use the FTP WRITE and FTP READ SCANNER can be used? I'm assuming you can update the scanner files via the LAN instead of plugging in the USB cable and I assume that is what the FTP WRITE/READ is for but I can not figure out on how to use it. Thanks.
Correct, You can update the scanner files using the FTP Writable Account. Need to use a FTP client such as the free FileZilla or my ProScan.
If using the FTP Writable Account then send a "GFM,UNIDEN" + CR command to the scanner first then send a "EFM,UNIDEN" + CR command afterwords. My ProScan will handle that automatically. The scanner will go into FTP Mode which is like Mass Storage mode. My ProScan will just read or write the Favorites and not the other folders.
Using the FTP Read Only Account doesn't need a GFM or EFM command and the scanner will operate normally while FTP Read operation is going on.
Before FTP in to the scanner, the scanner FTP Read Only Account and Writable Account needs to be set up with the User Name and Password.
Scanner menu -> LAN Settings -> Set FTP Server ->
Also read/write still requires the micro USB cable to be connected.
FTP read/write uses the Ethernet connection. If your thinking of plain ole read/write then you are correct.
