Quick Question about CB Range
k8krh
Go murs, license free, antennas are cheap<2 mtrs>,
DOCTOR
Dawn
Pinecrest,Fl
You're making a semanical error here. What the FCC considers a "base" or fixed station isn't the same as what the average person considers a "base". A fixed station or fixed base (that's the FBx designation) is the master transmitter be it a simplex,duplex, or repeater. That can be at the owner's location or on top of a mountain or building or anywhere remote. That's the base station. It also is required to have a higher tolerance .0025% stability then all the othe ancillary units. That also is (or used to be) the one that required complete calculation of losses and gains from radio to antenna for ERP. When a station sitting on a desk communicates with or through this station, it is a called a control station and only requires mobile stability, directional antenna, and the lowest power needed to establish communications. While people call this a base, it's in fact not. To add a little dimension to this, historically, many of what were called bases, weren't even radios even if co-located on the same property. They were essentially a remote control head either directly wired to the unit for local control or through a dc or phone line pair. The FCC term for that is a "Control Point" which can also be applied to a control station. That simply indicated that where that station was also contained those responsible for the system. When I got into this business in the early 70's, complete table top bases were a rarity. The station sat besides a desk in a 3' cabinet or somewhere else. Reasoning being that the "base" had to endure a 100% duty cycle as opposed to mobile and control stations didn't see more then a 20% duty cycle. In essense, that's true even today in a system that sees heavy usage. This my seem over the top for your question, but it's necessary to know how the FCC views the term when approaching a license.
milkman21218
Baltimore, Maryland
Yep! ;-) I was thinking of having a base station or repeater at my house!
Here it is straight of the FCC Website: "(a) Except for a GMRS system licensed to a non-individual, one or more small base stations or a small control station may be added to a GMRS system at any point where radio services are regulated by the FCC"
Therefor, it seems to me that I could have one or more base stations. One at each house for example.
Also, "a) An individual GMRS system licensee may permit immediate family members to be station operators in his or her GMRS system. Immediate family members are the:
(1) Licensee;
(2) Licensee's spouse;
(3) Licensee's children, grandchildren, stepchildren;
(4) Licensee's parents, grandparents, stepparents;
(5) Licensee's brothers, sisters;
(6) Licensee's aunts, uncles, nieces, nephews; and
(7) Licensee's in-laws."
This goes on to say that any of the above, including Grandparents could operate a GMRS station in my GMRS System. So, If I outfit each house with a unit, there is no reason why they couldn't use it. According to the FCC, I believe that I am correct.
Is it that they all must live in the same location in order to be covered? And not one license for muti-locations?
robertmac
To me the key in the OP is "reliable". CB is far from reliable. Just far far too many variables. Maybe in 5 years might be more reliable with out all the hash of skip. But then we factor in hand held, poor antenna. The way to go is what most have said, GMRS, or MURS.
They all have to live in the same house. The license only applies to family members that live in the same house.
Sent from Tapatalk
It does not say they have to live in the same house..............
You might be able to use handhelds at all three locations. Five watts should be adequate, as long as the building construction is not excessively thick.
Keep in mind that you will need a GMRS license for each of the locations.
Sent from Tapatalk
No you will not need 3 license ,it does not state that in the rules as they are immediate family.
(1) Licensee;
You are correct,people do not take time to read the entire rules and then begin to assume things,go ahead and get you license and get them on the air and enjoy....Seems like this thread had more to do with GMRS than CB.
Ranothil
I know :D I was trying to find the best radio service for my situation. CB got dropped pretty quick! Thanks for all of your help!
