Radio shack pro 652
AngWay
Curious
Buchanan, Va
As I have said you have very much to learn about 2way radios.
Repeaters and Repeater Controllers have options that installers can turn on and off each has a plus and minus.
But most installers turn on squelch tail with tone (what you are hearing) this works good where users are in the fringe and helps keep the repeater captured longer.
I know i have much to learn that's why i'm asking ,So are us saying there is nothing i can do about it?
I know i done asked about this but why does google say
Key points about the Pro 652:
  • Digital Trunking Scanner:
    It is designed to monitor digital trunking systems, including popular types like APCO P25, Motorola MotoTRBO, and EDACS.
    And when i search if MotoTRBO is DMR it says it is DMR.
buddrousa
History Lesson
The PRO-197 is the same as the PRO-652 and was invented and on the Market before DMR was invented.
DMR as was NXDN to be a more Price efficient Radio Format than P25.
Most all older Scanners Do not have enough Flash Memory to upgrade to newer Digital Formats this includes P25 Phase 2.
buddrousa
History Lesson Part 2
The Uniden 536 436 996P2 325P2 are all upgradeable scanners but we were told by UPMan before he Passed Away that these Scanners were at the edges of the Flash Memory so we could only expect limited Firmware Updates due to the Limited Memory Space.
We were also told that the SDS Scanners had more Memory but he Passed Away before we learned all the extras that were in the pipe.
Enjoi19
Ontario, Canada
Is this google AI telling you this? Probably the problem right there.
Whiskey3JMC
Don't feed the squirrels
Simulcastylvania, TE
Oh but if it's spewed by Google AI it must be true huh?
DMR is an open digital radio standard. MotoTRBO is Motorola's implementation of said standard. Not all DMR is MotoTRBO. Other players in the DMR game: Hytera, Tait Radio, Icom, and Kenwood not to mention various amateur radio manufacturers
AngWay
Curious
Buchanan, Va
Google does not know everything. It only knows what Google CEO wants you to know.
Well duh i know that but it's a search engine and i got to use to to find other stuff, would you prefer i used yahoo instead.
would the pro 652 decode any of This I know on some of those p25phase 2 sites it will say that it's phase 2 but most are still using phase 1 is any of that still phase 1?
dave3825
Suffolk County NY
Google (the search engine) is top notch. Google AI is not top notch. Google search will yield the correct info. Google AI gathers bits and pieces of different things from all over and is often filled with errors.
Pro 652 Google search.
Very first result actually takes you to RR Wiki where the page there really offers no details about the scanner..
If you ask Google (search engine) does pro 652 do DMR, google AI says .
Its always best to find a reputable place selling the radio and read the specs. Or google the specs. All of that info is on the web and not difficult to find.
Google AI says,
Since the 652 is new to you, you should read this front to back, then back to front.
Nasby
Ohio
The pro652 will work for the VA system as the talkgroups are labeled “D” meaning phase 1 digital (even though the system itself is phase 2). It may not work well with simulcast sites on the system. You may want to visit the VA state forum for more information.
hill
Middle River, MD
Virginia is mostly encrypted now on their STARS radio system. Just look at the treads on the Virginia Forum.
Even if not encrypted does really matter as the system is going to phase 2 and your PRO652 can't handle that. Plenty are listed as phase 1, but they have started to use phase 2 and no one has updated the database.
AngWay
Curious
Buchanan, Va
ok Thanks
AngWay
Curious
Buchanan, Va
Google AI says,
Alright thanks for that yeah i was looking at the AI
hill
Middle River, MD
I am not really in position to update the database. Don't live in Virginia, but deliver to Richmond area and points South and stay there at least one night. Also with all changes and updates they roll out more encryption daily and it really needs to be updated by someone there 24/7.
Really won't matter which phase it is with it mostly be encrypted even forestry and DOT assistance being encrypted.
Our days to monitor the Virginia STARS system will be ending soon with the encryption.
I really stopped any monitoring of STARS and removed it from.G5.
AngWay
Curious
Buchanan, Va
Since you have some knowledge of this, can you make a submission to get the db updated?
I have done the same thing i just removed STARS from my monitoring. it really sucks call your representatives and complain that's about all i know to do.
