Re-Banding
wesct
Connecticut
As of July 7, 2008
Hartford County
Hartford Hospital Security 860.8125 MHz DPL025
CCSU Police, New Britain: 856.8125 MHz DPL071
857.4125 MHz PL 114.8 RAFS 1
854.9125 MHz PL 114.8 RAFS 2
Windham County
Willimantic PD 854.2625 Mhz PL 162.2
New Haven County
Meriden PD 855.5125 MHz PL123.0
Meriden is also licensed for the I-Call re-banded frequencies
New Haven Fire :
854.4875 MHz DPL311
859.5625 MHz DPL311
New London County:
Groton Town PD
Ch 1 853.400 DCS 155
Ch 2 851.575 DCS 155
Sprague: 855.2625 MHz --license in effect 7-24-2006
Statewide:
Department of Corrections
854.1125 MHz; 857.6625 MHz; 859.5375 Mhz; and 859.6625 MHz- status pending
Thanks to the Radio Reference community for the updates.
wesct
wesct
Connecticut
As of July 8, 2008
Hartford County
Windham County
New Haven County
New Haven Fire :
854.4875 MHz DPL311
859.5625 MHz DPL311
New London County:
Groton Town PD
Sprague: 855.2625 MHz WQFI 471
Statewide:
wesct
wesct
Connecticut
As of July 8, 2008
Hartford County
Windham County
New Haven County
New Haven Fire :
854.4875 MHz DPL311
859.5625 MHz DPL311
New London County:
Groton Town PD
Statewide:
wesct
Refresh, once again
Cskib32087
If you read the post it says they are rebanding to the new I-Tac - I-Call freqs.
Why would any town do that when we all have to wait for the state to change the infrastructure first? The West Hartford cars will be the only ones in the state on the new channels, weird!
PJH
Due to the fact that WH has had their own I-xxx equipment for some time now...and that the state also has reachable repeaters. All you do it program the new and the old into the field radios and the consolettes. When everyone is switched over, you take the old ones out of the field radios and your done. Pretty simple.
Cskib32087
Why program now then remove the old, just wait and progrem in the new when the time comes and the entire region changes. Pretty simple.
PJH
In the public safety field, when things start to change over, and there is plenty of legacy stuff running around, you run both.
If your traveling in an area that is rebanded, but another area isn't...and you happen to be traveling in an area that isn't, how are you going to communicate? The new channels won't work on the old ones.
Here is an example.
West Hartford crusier is traveling to Whelen. ONLY the rebanded channels are in the radio. CSP hasn't rebanded down Route 9 yet, and the WHPD guy comes across an accident in an area with poor cell phone reception. He can't use his ICALL due to the rebanding, and he is out of range of his trunking system.
Now, with both channels in there, your good to go.
The ASTRO Spectra's can have 255 channels. Its not like the WH radios are THAT filled up. Plenty of room. 1000 channels with HOST12 in the XTL/XTS5000's. Programming in another zone or a few channels isn't going to break the bank.
awasser1
Apache Jct, AZ
West Hartford
Do the new frequencies even work yet for West Hartford? I tried them manually and havent heard anything yet as of the other day.
Lynch_Christopher
Winthrop, Ma
If stamford goes to 700 MHz does that mean that they will have to reprogram the new radio system that they just installed?
Lynch_Christopher
Winthrop, Ma
Are any other towns in Fairfield County planning on going to 700 MHz or staying in 800 MHz range once the rebanding is done?
cg
Connecticut
West Hartford has not changed yet.
Trunked radios can be programmed with any frequency that the system uses or will be using. When the old data channel stops, the radio should scan the programmed frequencies without user intervention and find the new data channels. If the system ID & Connect tones match, the system looks for the preprogrammed talkgroups that are attached to that system.
In other words, if the future system control frequencies were programmed into the radios, it will start working when the switch is thrown for the new freqs.
awasser1
Apache Jct, AZ
West Hartford
The reason I ask is because on the BCD396T the lastest firmware addresses the rebanding. But I am unsure what to fill in to the custom band numbers. The base Freq and offset. There's a plan 1 and plan 2. I wanted to understand what to put in there before it happens. I am sure it's simple but havent had one to test yet.
cg
Connecticut
that would be best separated from the rebanding thread and asked in the general Uniden forum.
I looked at my 996 and found the tables. I am sure there is a generic entry for it as the new Motorola channel numbers are common nationwide.
chris
wesct
Connecticut
Hartford County
Windham County
New Haven County
New Haven Fire :
854.4875 MHz DPL311
859.5625 MHz DPL311
New London County:
Groton Town PD
Statewide:
